Author Topic: Speedometer needle problem  (Read 2975 times)
Offline kevinu
« on: May 20, 2020, 10:12:51 AM »
A month or so ago, I repaired the odometer gears and wasn't sure how to get the speedometer needle reattached after the repair.  After two tries, I had it on and sitting at 0 mph when it should be.
Yesterday, I did a very hot (<100 F) ride that included a section of bumpy dirt road, and now the needle is at 140 mph when sitting still.
I know it sits on a very delicate pin, and care must be taken to not damage this pin.  I'm guessing I never really had it set on the pin correctly in the first place and the vibrations knocked it loose.  I need to take the needle off the pin and try to get it reset again at 0.  Should I add some type of glue before put it back on the pin?
Or maybe the problem is the pin itself?
  • Alpine, Texas
  • 1994 K75
Re: Speedometer needle problem
« Reply #1 on: May 20, 2020, 10:21:30 AM »
Pushing it fully onto the shaft should secure it; it's a press fit. Maybe the shaft and its connection are damaged. I'd expect a loose needle to fall off but there's no telling until you get in there and take a look.
Offline kevinu
« Reply #2 on: May 20, 2020, 10:36:02 AM »
Now I have to find the time to take it apart and try the repair...
  • Alpine, Texas
  • 1994 K75
« Reply #3 on: May 20, 2020, 10:45:48 AM »
These units aren't examples of Motometer's finest hour and can be exasperating, especially the older ones without the benefit of Gore-tex ventilation in the back panel. On the other hand, they can offer practice in equanimity.
« Reply #4 on: May 20, 2020, 01:01:02 PM »
Smoking on startup and a flaky speedo are actually precision designs to give the bikes character.  Otherwise they would be perfect and as boring as a refrigerator.
