Author Topic: Auxiliary light prefered here. LED or HID/92 Bmw K75 standard  (Read 4638 times)
Offline lefthander
 Hello all,
 I just purchased from EagerBeaver the wiring loom to add the relay to my headlight. I bought the one to be able to add auxilary lights from my hi-beam. Ca anyone suggest what auxilary lights to get. I have a pair of warn auxilary lights that are hid. So should I stay with them and try those out, or would the wiser approach be to go with leds. I am not a lighting expert by far, however the little I've read it seems the leds have the edge. Anyway if you have a brand suggestion and a style or output capability that is favored I would love to hear back from you. Thank you, John
  • Savannah GA
  • 1992 k75, 2002 1150gs
Offline lefthander
Re: Auxiliary light prefered here. LED or HID/92 Bmw K75 standard
« Reply #1 on: May 17, 2020, 04:11:21 AM »
 Also any help with mounting the lights would be great. Someone said to use the reflector on the forks, but I'd like something a little higher. I do have a blacked out bmw standard fairing on it. Any thoughts will be appreciated. If you have pictures that would be great as well. Thanks again.
  • Savannah GA
« Reply #2 on: May 17, 2020, 08:31:39 AM »
The name of the company is Eastern Beaver. LEDs draw much less current than incandescent bulbs for the same amount of light and tend to be more durable. Here's a mount that allows location of auxiliary lights onto the upper fork tubes of a naked Brick. There are many other adaptations out there.
Offline lefthander
« Reply #3 on: May 17, 2020, 05:57:37 PM »
 Sorry, it was Eastern Beaver. Great site. Those mounts do look nice. Thanks for your help.
  • Savannah GA
Offline mobydick
« Reply #4 on: May 20, 2020, 10:44:21 PM »
Not knocking LED efficiencies but if I need light a 1/4 mile down the road HID is my first choice. I use LED's as well on both my K bikes for short highway distances but they suck at long distance.
I installed an HID ($118 US/pair) headlight bulb on my brick recently and it is soooo much better than the 90 watt incandescent bulb it replaced.  The downside is no h/low beam, just one range.
I still need good pencil beam spots.   Any recommendations?  XRay Vision has some but they may be too hi a wattage for my alternator and too large a face.
mobydick
* 20200520_185013.jpg (111.85 kB . 646x364 - viewed 440 times)
* 20200520_185104.jpg (26.14 kB . 324x576 - viewed 478 times)
* 20200520_185357_004.jpg (40.82 kB . 324x576 - viewed 455 times)
  • coquitlam bc canada
  • 1987 K75c 57k miles ex Burbank, 2001 K1200RS
