With the Killswitch on there are no lights no blinkers. I can hear the pump start in the tank. I have checked all the fuses they are good. The clock is showing the time ticking away and I checked the battery with my multimeterAnd it reads 12.89 V.Any ideas what I should look at?Thanks in advance.
1- Double check top most Fuse#1
2- Ignition full on- Does the horn work?
3- Pull the clutch lever in before starting. Any change?
Two interlocks interact: It should start if its in neutral; or if the clutch lever is pulled if in gear. The gear position indicator switch at the transmission end and clutch switch up by the clutch lever.
So, if in gear pulling the clutch lever should allow it to crank. If not, the clutch switch is suspect.
If the neutral light fails to come on the GPI switch seems faulty. If both get bad it won't start.
4. No key required. Take voltmeter +POS lead to the battery POS terminal
Voltmeter -NEG lead to Starter terminal post should read battery voltage. No reading - Starter issue open ground
5. The following will require Ignition Key but Do Not Push The Starter Button
Take a decent jumper wire connect to the Starter terminal post the other end to ground
Turn Ignition Switch On: the headlight and instrument cluster should work - Starter issue open ground- remove jumper
6. If when doing #5 the headlight and instrument cluster did not work- possible Load Shed Relay issue
Switch Load Shed Relay with the Horn relay
Hold Clutch lever in until you've solved the problem
funny how the Griffoon and Professor carry on a conversation in thread
