I'd remove the fuel pump then bench test it with a 12 volt battery to determine if it's seized. Disconnect the moto's battery ground wire. Remove the fuel cap assembly, drain the tank using a bulb siphon, disconnect the wires from the pump, disconnect its fuel hose and filter basket vent hose (if it has one, some pumps have a filter sock instead), squeeze inward on the tabs securing the pump holder to its platform then withdraw the holder and pump together.
Take photos of how the pump is oriented in its holder; post them here.
