Author Topic: Removing Combo Pump Shaft  (Read 2513 times)
Offline aussiebeemer
« on: May 03, 2020, 03:08:06 AM »
I am rebuilding my K75 Oil/ water pump and need to replace the shaft. What is the best way to remove the shaft from the gear? I have tried WD40 and a firm hammer hit while supporting the gear with wood on a solid surface. Appreciate suggestions.
Re: Removing Combo Pump Shaft
« Reply #1 on: May 03, 2020, 08:07:01 AM »
Heat up the shaft with a heat gun or hair dryer. Soak the shaft in Liquid Wrench, Kroll, PB Blaster or another rust penetrant. WD40 isn't as effective. Wait ten or 20 minutes then go after it with a dead blow mallet with the nut or bolt fastened on the shaft, or with the hammer and a hardwood block as you did previously.
Offline volador
  • NEEDS MORE CHROME
« Reply #2 on: May 03, 2020, 11:26:50 AM »
this ought be fecking good an aussie with a BFH...
you got a part number for that replacement shaft or you working at the Trades Guild?
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
