Author Topic: Additional horn relay...answered thanks  (Read 3008 times)
Offline Quzzy
« on: April 30, 2020, 01:39:38 PM »
Have just ordered a Denali Soundbomb horn, it comes with a relay which I would happily use, but as theres an existing standard relay, is it necessary?
If I just use the existing, perhaps I should beef up the wire from that to the horn?
thanks
  • Gironde
  • K100
Offline kioolt
Re: Additional horn relay...necessary?
« Reply #1 on: April 30, 2020, 04:50:04 PM »
It would depend on what the amp rating is on the oem relay and how much more the Denali uses.  When I installed a Denali Soundbomb on my bike I determined that there was an increase  in current draw that was enough to be concerned about.  I don't remember how much but I decided it would be prudent to install the relay and bigger gauge wire.
Offline Quzzy
« Reply #2 on: April 30, 2020, 05:05:09 PM »
Thannks, did you use the OEM relay to trigger the additional one?
  • Gironde
  • K100
« Reply #3 on: April 30, 2020, 05:29:41 PM »
I fitted a Nautilus 140 Db air horn and used the OEM  horn wire to trigger it. I had it configured that I could switch between the OEM horn and the air horn plus the OEM. I was originally  told that the 140 Db horn was illegal but have since found out that it is not a problem.
« Reply #4 on: April 30, 2020, 07:29:31 PM »
The OEM horn relay has contacts rated for 30 amps.  The 15 amp fuse that supplies the horn will blow before there is a problem with the relay or the wiring.
The relay supplied with the aftermarket horn is to protect the horn button contacts on bikes that don't already have a relay.
Offline Quzzy
« Reply #5 on: May 01, 2020, 03:24:30 AM »
Thank you gentlemen, thats all I need to know.
Q
  • Gironde
  • K100
