Author Topic: K75 basketcase, what needs to be plugged in to start?  (Read 3000 times)
Offline Tjrad
« on: April 17, 2020, 01:22:47 PM »
Hey all, names Tyler, this is my first post, I apologize that its a question.
Picked up a basketcase 91 K75S yesterday as a Coronavirus project.  Everything is there except the front and rear fairings, so no taillight, headlight, turn signals or horn.
Question is what needs to be there other than the battery, gauges, ignition, starter and computer? Do I need to terminate or short those other things, I’ve looked all over but cant find the answer.  I am cleaning the ignition switch now but hoping to try to start,
right now with the battery hooked up I only have a clock.
Dont work on a lot of bikes with computers and this is my first bmw,  appreciate any help
  • Santa Cruz
  • 91 k75s
Re: K75 basketcase, what needs to be plugged in to start?
« Reply #1 on: April 17, 2020, 01:32:40 PM »
northern commiefornia... you in the state of jefferson...
what is that battery reading key off...
poast up some photos of this 91 750 s so we can see exactly what you gotts there...
« Reply #2 on: April 17, 2020, 01:41:59 PM »
check the inside of the tank for dissolved fuel pump mounting and make sure the gas is fresh.  Sounds like everything is there you need to start, ignition and kill switch good place to start.
Offline Tjrad
« Reply #3 on: April 17, 2020, 01:52:26 PM »
Battey is brand new reading 12.7, cost more than the bike.  Have the ignition switch apart for cleaning and then over to the kill switch, took out the starter and cleaned it.  Took off the tank and cleaned it.  Removed all grounds and cleaned them and their mounting points.   Hoping the ignition and kill gets me something more than a clock.  Thanks guys, I’ll try to get some pics up later.
Not everybody from Ca is a Commie!!! Some of us were just born here :laughing1: :laughing1:
  • Santa Cruz
  • 91 k75s
« Reply #4 on: April 17, 2020, 02:11:49 PM »
Welcome!  First, a fully charged battery should show at least 12.8 volts.
Second, a Clymer manual is a good investment, especially since it has electrical diagrams of your bike.
As an upstate subject of the Philosopher King Il Douche Andrew the Cuomo I fully sympathize your situation in the Jefferson province of Commiefornia.
« Reply #5 on: April 17, 2020, 02:29:43 PM »
so... with key on you have no dash lights or headlight... is that right...
you want it in nuetral on the centerstand with the sidestand up...
do all this so we can rule out all that...
Offline Tjrad
« Reply #6 on: April 17, 2020, 06:05:48 PM »
All good info, thank you. Especially the part about the kickstand. I’m getting closer to being able to try here, but have one more question
Ball bearings in the ignition switch? How many should there be and where did they go? I have one,It seems like there should be four
  • Santa Cruz
  • 91 k75s
« Reply #7 on: April 17, 2020, 07:11:49 PM »
It's been a couple years since I've been in an ignition switch, but I'm pretty sure there is only one ball bearing and it's for the detent and has a spring behind it.
« Reply #8 on: April 17, 2020, 07:26:38 PM »
Offline Tjrad
« Reply #9 on: April 17, 2020, 08:17:16 PM »
Got Juice!  It was the ignition switch, was filthy, now just gotta change the oil and put gas in her tomorrow and see what we got.  I’ll post some pics up tomorrow when I get the tank back on.  Thanks for the help today!!!
  • Santa Cruz
  • 91 k75s
