Author Topic: My K75S Runs for a few minutes - Fuel Pump Issue  (Read 6221 times)
Offline RZRob
« on: April 15, 2020, 07:57:58 PM »
Hi folks,
I recently picked-up an '87 K75S that had been sitting for years. The fuel pump and sender unit had decomposed to a blob. I replaced both and the bike started fairly quickly and after a few minutes the bike ran like it had no issues. I went an a 5 mile trek around my neighborhood. No problems.
A few days later I went to take it for a ride. It started and ran a total of about 5 minutes then sputtered to a stop. I pulled over and pondered life cycled the key a few times and it started right up and ran for another few minutes. This seems to be a predictable repeatable consistent issue. Upon inspection it seems like the fuel pump is NOT running when the bike dies, and until I wait a couple minutes, nothing will make the pump cycle.
Any ideas?
RZ Rob
  • California
  • '87 K75 RS
Re: My K75S Runs for a few minutes - Fuel Pump Issue
« Reply #1 on: April 15, 2020, 08:09:48 PM »
4 pin... needs mystery oil techron no corn ethyl lotts of red line miles... plus all new rubbers...
dont take it to irv severs... take it to liors...
https://liorsmotoride.godaddysites.com/
Offline RZRob
« Reply #2 on: April 15, 2020, 08:14:26 PM »
I barely understand. I did add some Techron before taking it out today. What do you mean b y new rubbers. Bike runs great while the pump is pumping. I tend to be hard on the throttle within reason. But it'll just all of the sudden sputter out and stop until I pull over and sit a couple minutes.
RZ Rob
  • California
  • '87 K75 RS
« Reply #3 on: April 15, 2020, 08:16:30 PM »
post up some photos of this moto...
ok then... start with the 4 pin...
its #3 here...
http://www.motobrick.com/index.php/topic,11033.0.html
Offline RZRob
« Reply #4 on: April 15, 2020, 08:19:53 PM »
This is the part I don't understand. What do you mean by 4-pin? Are you mentioning something about the plug for the sender unit? Please elaborate.
RZ Rob
  • California
  • '87 K75 RS
« Reply #5 on: April 15, 2020, 08:51:21 PM »
The dreaded 4-pin is the connection from the loom to the fuel pump.  It is a 4-pin connector (hence the name - catchy huh?) on the RHS side of the bike near the rear of the tank.  They are famous for playing up.  Find it, unplug it, clean the heck out of it and connect it again.  If it dies on the road just unplug and plug it again a few ties ad it should start working (mine always does)
Many members have also replaced the oem 4-pin connector with a new waterproof one to fix the issue.
Good luck
« Reply #6 on: April 15, 2020, 10:10:20 PM »
As Jo and FC stated known problem, so save yourself a lot of aggravation replace it with a good brand waterproof one from your local electronics store. Picture is of an aftermarket one.
* Four Pin connector.jpg (52.14 kB . 512x384 - viewed 674 times)
Offline RZRob
« Reply #7 on: April 15, 2020, 10:17:37 PM »
I totally believe this is what's going on.
I'll investigate and report.  Pics to follow.
RZ Rob
  • California
  • '87 K75 RS
Offline beemuker
« Reply #8 on: April 16, 2020, 04:21:27 PM »
RZ Rob
I hope you are right, but belief will only take you so far. But might as well start with the easy fixes.
  • Panama City, FL
Offline Paul_Waterloo
« Reply #9 on: April 16, 2020, 09:15:00 PM »
Do you know where to find a connector like that on the web, I quickly searched, but couldn't find anything. I like the looks of it.
  • Chicago
  • 1993 K110LT, 2003 K1200GT
« Reply #10 on: April 16, 2020, 09:30:53 PM »
Your local electronics store should be able to help you. Alternatively go to Ebay and search for 4 pin waterproof connector.
Offline volador
  • NEEDS MORE CHROME
« Reply #11 on: April 17, 2020, 12:17:07 AM »
Easter Beaver Sumitomo TS090 Sealed Connectors
the 'Sumitomo Not in Catalog Male 4P Connector'  3/4 of the page down looks very similar discreet connector
I get extra pins and seals
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
« Reply #12 on: April 17, 2020, 07:52:13 AM »
Great, bought two of them.
  • Chicago
Offline RZRob
« Reply #13 on: April 18, 2020, 02:05:39 AM »
I saw my 4-pin in the factory harness was corroded. I distorted the female side and cleaned them. The male side was new. Bike runs well.
RZ Rob
  • California
  • '87 K75 RS
« Reply #14 on: April 18, 2020, 02:25:47 AM »
Replace it with the waterproof one while you have the time. The OEM one will fail again in the most inconvenient moment.
« Reply #15 on: April 18, 2020, 06:04:15 PM »
I have some to share.
https://www.motobrick.com/index.php/topic,12347.msg109228.html#msg109228
Offline RZRob
« Reply #16 on: April 19, 2020, 10:46:44 AM »
Hi Stokester. I'll donate $10 if that's what you had in mind. If not, let me know and let me know how to donate.  I'd like to upgrade these connectors on my bike.
Robert Covington
7870 E. Menton Ave.
Anaheim, CA 92808
7l4-264-862l
RZ Rob
  • California
  • '87 K75 RS
