Author Topic: K 1100 brake grab but will not stop at low speed.  (Read 3028 times)
Offline cbelawn
« on: April 12, 2020, 04:34:00 PM »
I start diwn my driveway and end up in the road because I pull on the brake lever and it feels like it's catching on something and will not engage the brake. It took out the brake actuator pin and Lube that up has not seen to help. Only a low low speed does this occur. Anyone have any advice?
  • skaneateles
  • k
Re: K 1100 brake grab but will not stop at low speed.
« Reply #1 on: April 12, 2020, 05:12:27 PM »
have you done a full bleed where you have good lever and pedal..
does this moto have oe rubber brake hoses or stainless brake lines...
how much meat is on the padds...
when did the brakes work properly... what has been done to this moto since then...
generally downhill driveway id be on the back brakes until i came to full stop... then hold it with the front as i wheelied onto the road...
poast up some photos of this moto...
Offline cbelawn
« Reply #2 on: April 12, 2020, 06:12:35 PM »
New pads, worked in the fall,sat all winter,I did bleed brakes at caliper. Rubber horses
  • skaneateles
  • k
Offline cbelawn
« Reply #3 on: April 12, 2020, 06:16:51 PM »
Good pedal and stops goog at higher speed
  • skaneateles
  • k
« Reply #4 on: April 12, 2020, 06:22:34 PM »
How old are the rubber hoses?  If original, bet that is the problem.
« Reply #5 on: April 12, 2020, 06:50:04 PM »
how long have you had this moto...
so.... the problem is front brakes because you said lever in your 1st post...
so... if you are rolling 50mph and pull the brake lever hard does the abs engage...
so... i asked for photos... now is the time to post them here...
Offline cbelawn
« Reply #6 on: April 18, 2020, 02:12:10 PM »
Abs works
The leaver acts like its hitting a stop. Not like a fluid problom owned this for 2 years
* 20200418_140558.jpg (54.01 kB . 768x576 - viewed 474 times)
  • skaneateles
  • k
Offline cbelawn
« Reply #7 on: April 18, 2020, 02:13:48 PM »
Been snowing here
  • skaneateles
  • k
