Author Topic: Trash Hauler’s first K100 Cafe Racer Project  (Read 10907 times)
Offline Trash Hauler
« on: April 07, 2020, 06:53:41 PM »
Disassembly
I started the disassembly last week after cleaning out the garage. The biggest challenge was working out how best to work on the engine once I have removed it from the frame. With the clutch gearbox arrangement being similar to a car, I could see an automotive engine stand would work nicely. So I purchased the cheapest stand I could get ($117) and the photos below show the progress.
I also made up a steering lock and left the front end on while I separated the frame. This way I could sit the rear seat frame on a bench and the bike was stable while removing the gearbox and engine.
1. Bike before the project (I bought the bike sans the fairings and luggage)
* 85F17153-71E0-4E34-B8E5-471F5779ACAB.jpeg (50.83 kB . 432x576 - viewed 1081 times)
2. Initial disassembly
* 2CE89121-A5CB-406D-862D-52643D1A74B9.jpeg (47 kB . 432x576 - viewed 1112 times)
3. Steering lock
* 8E65BC1A-CF2C-4A63-A37A-3DCDB61D4899.jpeg (44.72 kB . 431x576 - viewed 1092 times)
4. Seat frame on bench for gearbox / engine removal
* C448C80D-790C-4FD9-9E11-803EEB64BBA1.jpeg (51.1 kB . 432x576 - viewed 1121 times)
5. Gearbox removed
* 26E64FFE-01E9-4000-839E-E996CD5E9898.jpeg (47.42 kB . 452x576 - viewed 1113 times)
6. Engine removed and on stand
* 1F39CD24-8C91-4BFE-B9DB-26424DCA7A02.jpeg (78.95 kB . 768x576 - viewed 1023 times)
7. Frame with front end and loom still to be removed.
* 6E2BFCFA-F75B-40A6-84DB-02999F113168.jpeg (75.88 kB . 768x574 - viewed 1106 times)
TH
(Edited to correct orientation of images)
  • Sydney
  • 1985 K100 RS
Offline volador
  • NEEDS MORE CHROME
Re: Trash Hauler’s first K100 Cafe Racer Project
« Reply #1 on: April 08, 2020, 09:46:50 AM »
Looking good you're off to a good start. Where did you get the engine stand?
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
« Reply #2 on: April 08, 2020, 06:14:20 PM »
Supercheap Auto Parts - Sydney Australia
Engine Stand. https://www.supercheapauto.com.au/p/sca-sca-engine-stand-560kg/219511.html
  • Sydney
  • 1985 K100 RS
« Reply #3 on: April 08, 2020, 06:46:29 PM »
 :welcome
Offline volador
  • NEEDS MORE CHROME
« Reply #4 on: April 08, 2020, 07:15:07 PM »
Crikkey, was thinking Sydney Nebraska not another downunder bloke
there's a tribe of you'll here you just met chief 'Regards Martin'
  • NYC NY
Offline volador
  • NEEDS MORE CHROME
« Reply #5 on: April 08, 2020, 07:42:17 PM »
Bonzer engine stand
Can you give us a piccy of stand mounting to intermediate housing.
Just an observation I would be concerned to exert to much force on that intermediate housing maybe a support under the oil pan would alleviate some of the engine weight
  • NYC NY
« Reply #6 on: April 09, 2020, 02:33:50 AM »
:welcome
Thanks Martin - good to be here
  • Sydney
  • 1985 K100 RS
« Reply #7 on: April 09, 2020, 02:35:11 AM »
Bonzer engine stand
  • Sydney
  • 1985 K100 RS
« Reply #8 on: April 16, 2020, 09:52:25 PM »
Frame and engine disassembly complete ready for blanking, degreasing and glass blasting.
* FDDF6407-035B-487B-BB01-B7D92601C088.jpeg (67.28 kB . 768x574 - viewed 1083 times)
* 3B682375-F6E1-48FE-9303-61BDACDC820E.jpeg (43.29 kB . 428x576 - viewed 1087 times)
  • Sydney
  • 1985 K100 RS
« Reply #9 on: April 23, 2020, 07:02:00 PM »
I have ordered an Injector Pulser Tester from AliExpress to go with my ultrasonic cleaner. $26 USD.
I will post a review once I have used it.
https://www.aliexpress.com/item/33008882556.html?spm=a2g0s.9042311.0.0.3a854c4dPKo9W9
* A277F4FD-8C99-4E63-8E3F-5A1E22AC9D61.jpeg (34.09 kB . 611x576 - viewed 1044 times)
TH
  • Sydney
  • 1985 K100 RS
« Reply #10 on: April 23, 2020, 08:27:53 PM »
You might want to get a 250 ML graduated vessel to compare injectors. Home brew supply shops have them. I built an air powered test unit set to 35 PSI due to not wanting to blow up my workshop. On the advice of a local injector workshop I use lacquer thinners to clean the injectors which is a lot cheaper and more effective. The vapours however do melt some types of plastic for example the lid of my sonic cleaner which did eventually solidify. I would remove the pintle caps, filter screens and "O" rings if using thinners. The thinners did however restore a set of Ford injectors that nothing else would clean and had been rejected by another injector shop.
« Reply #11 on: April 23, 2020, 08:33:08 PM »
Thanks Martin - great advice.
  • Sydney
  • 1985 K100 RS
« Reply #12 on: April 23, 2020, 08:56:04 PM »
TH see here http://www.motobrick.com/index.php/topic,12153.msg107177.html#msg107177 The test unit has changed a bit since it's inception the plastic bottle has been changed to a graduated vessel and I'm now using a Sun test pulser.
« Reply #13 on: April 23, 2020, 11:21:03 PM »
Thanks Martin - I like your setup. I am going to build one the same. I think I have an old fire extinguisher in the shed that may work as the container.
TH
  • Sydney
  • 1985 K100 RS
