Author Topic: Instrument pod reassembly. Corona project 1  (Read 8617 times)
« on: March 29, 2020, 07:34:50 PM »
Amongst my recent K75s panel and bits was this. Although disassembled it looks in good condition and worth putting a bit of effort into. I'll either get it back together or go mad trying.
* Instruments disassembled.png (54.16 kB . 768x576 - viewed 1535 times)
Offline natalena
Re: Instrument pod reassembly. Corona project 1
« Reply #1 on: March 29, 2020, 08:01:04 PM »
Looks like a great project. Here in the states, it'd be a good chance to reset the odometer and turn the speedometer pot so it reads "mph" more accurately. The lenses look fantastic.
  • MST
« Reply #2 on: March 29, 2020, 08:37:54 PM »
Martin, thanks for reminding me that the "new" K100RS cluster has a loose bulb in it that is blinking.  It will be a good project for the incarceration.
« Reply #3 on: March 29, 2020, 09:29:47 PM »
I was making progress until I found that I seem to be missing a circuit board. I'm using an early set of instruments as a reference which is different. Mine appears to never have had the larger board which is attached to the speedo face. I don't know whether I can remove the circuits from the early board to make it work. The early one has a red light next to the 4L fuel light with a small silver label with Japanese characters on it, a red and yellow wire goes from the light to the larger circuit board. Three wires black blue and red go from this board to the board that is missing.
* Instrument missing circuit 1.png (55.22 kB . 768x576 - viewed 1493 times)
* Instrument red warning light.png (41.17 kB . 768x576 - viewed 1489 times)
Offline volador
  • NEEDS MORE CHROME
« Reply #4 on: March 29, 2020, 11:41:49 PM »
Looks like another Alli-babba special nothing these Chi-coms won't counterfeit
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
« Reply #5 on: March 30, 2020, 12:00:34 AM »
I think the red warning light might be a speed warning light unique to Japan. I wish I could read Japanese. As such I could probably remove the circuit board that I want from the early speedo. However I am reluctant to do so because I have never seen this light fitted before and I would rather keep it as an early working speedo. I also have a couple of mates with early Bricks who might require it one day. If anyone has a wrecked speedo and is willing to part with the required circuit please contact me. At this stage the speedo is back together awaiting the circuit. I wound it forward to match mine then realised I should have left it on it's original mileage. I'll rectify that later.
* Speedo Reconditioned 1.jpg (40.68 kB . 768x576 - viewed 1543 times)
Offline volador
  • NEEDS MORE CHROME
« Reply #6 on: March 30, 2020, 12:17:31 AM »
I think the red warning light might be a speed warning light unique to Japan. I wish I could read Japanese...
characters read 'LIDAR Detector Bluetooth compatible Android Apple iPhone'
  • NYC NY
« Reply #7 on: March 30, 2020, 12:29:09 AM »
Good try Vol the first two characters represent the word speed the next two characters represent alert. Still working on the fifth.
Offline natalena
« Reply #8 on: March 30, 2020, 07:48:42 AM »
Tategaki, Vol-chan, are you reading right to left? ;)
  • MST
Offline volador
  • NEEDS MORE CHROME
« Reply #9 on: March 30, 2020, 08:50:18 AM »
Yokogaki, Nata-chan, left to right ;)
  • NYC NY
« Reply #10 on: March 30, 2020, 09:00:35 AM »
this my ongoing corona project one...
* jocoronabirusproject1.jpeg (32.66 kB . 264x399 - viewed 1479 times)
Offline Skunky
« Reply #11 on: March 30, 2020, 04:13:58 PM »
* Slow Down.png (14.3 kB . 581x272 - viewed 1462 times)
  • Derby GB
  • BMW K100lt BMWK1100lt
90 K100lt 97 K1100lt
Honda FMX650 Honda CB400F
« Reply #12 on: March 30, 2020, 04:42:12 PM »
Thanks Skunky that's close to what I got. The first two characters translated as speed the second two characters translated as alert. I haven't bothered with number five.
Offline Skunky
« Reply #13 on: March 30, 2020, 05:22:58 PM »
And 'Slow down you twat!' looks completely different
  • Derby GB
Offline TommyT
  • New Brick Owner
« Reply #14 on: March 31, 2020, 07:48:45 AM »
During rebuild did you notice how the knob for trip odometer is attached to the rod that turns that meter? I ask because I have an pod that is missing that knob and I am wondering how I will fix that problem.
  • Olive NY
« Reply #15 on: March 31, 2020, 04:09:33 PM »
Tommy to remove it just give it a firm pull. To install it fit it in the hole and push. The knob should look like the picture. I some rare cases you might end up with just the black plastic piece. In that case I think you may be able to remove the back and reassemble the knob.
* Odometer Knob.png (43.72 kB . 768x576 - viewed 1447 times)
Offline TommyT
  • New Brick Owner
« Reply #16 on: March 31, 2020, 07:59:55 PM »
Thank you for the tip and picture. Now I have to find an used knob to replace my missing one.
  • Olive NY
