Author Topic: BEP 3.0 vs m. Unit Blue  (Read 4404 times)
Offline Supershooter
« on: February 28, 2020, 06:31:13 PM »
The gauges in my lunchbox don't all work and when I inquired about getting them fixed I was told it was too far gone. So I'm going to add an aftermarket speedometer and gauge cluster. What are your thoughts on using a BEP 3.0 vs a M. unit Blue? I'm not sure I need all the tech the m unit brings but I'd probably appreciate it as time goes on. Please share your thoughts.
Supershooter
  • 85 K100 RT
Offline volador
  • NEEDS MORE CHROME
Re: BEP 3.0 vs m. Unit Blue
« Reply #1 on: February 28, 2020, 09:27:29 PM »
my lunchbox
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
« Reply #2 on: February 28, 2020, 09:57:35 PM »
Supershooter
Unless you plan on spending a lot of time around dumpsters on rainy afternoons taking pitchers of your yuneek bike you might want to just get a used cluster and plug it in.
Offline Skunky
« Reply #3 on: February 28, 2020, 10:07:30 PM »
Supershooter
Hi Sharpshooter, There is no BEP vs M. Unit Blue they are completely different things. The M. Unit is a rewiring system that can replace the electrical system relays and fuses with an electronic set built into a snazzy box. If you are fitting an aftermarket speedo you will need the BEP 3.0 or an equivalent such as the
Axel Joost  https://www.digital-speedos.co.uk/accessories-c10/electrics-relays-wiring-c63/elektronikbox-bmw-k100-k75-series-elektronic-box-the-ultimate-system-for-simplifying-your-wiring-p815
or the Tenet from 5 aces. Which also supply the speedo
https://fiveaces.hk/index.php/package?filter_catid=90
I used the BEP on my build and I don't know of anyone who used any of the others.,
  • Derby GB
  • BMW K100lt BMWK1100lt
90 K100lt 97 K1100lt
Honda FMX650 Honda CB400F
