Author Topic: Spline final drive lube data  (Read 7858 times)
Offline schrocketeer
« on: February 18, 2020, 11:24:25 AM »
Here is some data for Final Drive spline lube discussion. The two photos on the left are at my first tear down. I didn't have Staburags or HondaMoly, so I used Valvoline Full Synthetic from Advance Auto. The two pictures on the right are from my inspection this weekend, after 15k miles with the Valvoline. From what I can see, there is no degradation of either of the connecting side of the splines. I do have Staburargs from Beemerboneyard for the clutch splines and the final drive splines I'll finish up this week.
* IMG_20180706_175906994.jpg (27.42 kB . 324x576 - viewed 740 times)
* IMG_20180706_175847103.jpg (21.3 kB . 324x576 - viewed 708 times)
* IMG_20200216_201423863.jpg (75.91 kB . 768x576 - viewed 705 times)
* IMG_20200216_195323532.jpg (43.16 kB . 432x576 - viewed 718 times)
* IMG_20200216_195302630.jpg (72.3 kB . 768x576 - viewed 760 times)
  • North Alabama
  • 1985 K100RT very original
Ken
Current: 85 K100RT, 09 DL650, 16 4RT260, 97 XR100, 70 CT70, 06 YFM400
Past Bikes: 86 K100RT, 85 K100RS, 07 SV1000S, 80 KL250, 99 GS1100, 85 K100RT, 86 VFR700, 91 XR250, 95 VLX600, 86 TRX250, 02 GZ250, 83 Z50R, 78 ATC90, 86 XR250, 79 XR500, 72 AT1, 75 YZ360, 78 DT400, 75 DT125, 73 Trail 70
Offline Past-my-Prime
Re: Spline final drive lube data
« Reply #1 on: February 23, 2020, 09:44:30 PM »
Goes to show ya.
Better to lube than not.
« Reply #2 on: February 25, 2020, 01:01:45 AM »
That must have been a happy moment. icon_cheers
Offline volador
  • NEEDS MORE CHROME
« Reply #3 on: February 29, 2020, 06:28:03 PM »
Inconclusive test results
Z=16 are less prone to wear vs. Z=20 FD & DS
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
« Reply #4 on: February 29, 2020, 09:03:08 PM »
easy way to check spline status without taking final drive off..
put bike on center stand.  put in neutral.  grab back tire and gentle roll it forward and back.  if all the splines are perfect and the final drive is good, there will be NO "slop".  the more slop you feel, the worse the spline wear is.
« Reply #5 on: March 01, 2020, 10:34:16 AM »
I should have known.  I had a TON of slop, like 3-4" or rotation of the back wheel!!
I'm not going to repost what the FD looks like but suffice to say, I'm looking forward to installing a replacement (once we work out logistics of shipping and payment).
« Reply #6 on: March 01, 2020, 11:42:05 AM »
my 94 has a new driveshaft and a fresh "Anton" fully rebuilt FD.  there is literally ZERO slop.  shifts are soooo smooth and on/off throttle transitions are seamless.  awesome.
my 92 has original, well maintained DS and FD.  61k miles.  a little bit of slop, but not much.  the difference in how the two bikes shift and respond is night and day.
