Author Topic: Reuse of shaft in water/oil pump K100  (Read 4275 times)
Offline kjott
« on: January 01, 2020, 04:14:41 PM »
Hi!
I'm currently rebuilding the water/oil pump on my K100. Do you guys think its possible to reuse the shaft with the amount of pitting shown at the attachment?
  • 86' K100RS
86' K100RS
Re: Reuse of shaft in water/oil pump K100
« Reply #1 on: January 01, 2020, 04:50:15 PM »
did you know inge karlsen from fredrikstad norway...
thanks for the photo... some will say smooth it out and roll with it...  if it was my brick id replace it...
i dont wanna be 2000 miles from home and have that failure... final drive or drive shaft ok because i gotts spares that can be frdexed... butts not that... and my aaa aints good for 2000 all at once...
Offline kjott
« Reply #2 on: January 01, 2020, 05:31:44 PM »
Ah, OK. In general, is the leakages coming from bad seals or a bad shaft like mine then?
I think the bike had oil in the water, because the walls inside the pump had a black layer to it (recently bought it).
Nope, did not know Inge :/
  • 86' K100RS
86' K100RS
Offline Imlhaas
« Reply #3 on: April 11, 2020, 12:28:37 PM »
What did you do?  I am looking at a similar issue and am unsure if I should use or replace the shaft. Inside of this pump was clean, just oil from the weep hole.
  • PA
  • 1995 K75RT / 2017 R NineT
Offline volador
  • NEEDS MORE CHROME
« Reply #4 on: April 11, 2020, 01:04:27 PM »
Welcome. A closer pic would be helpful
Shaft looks like some minor discoloration. If it is not badly scored or pitted would reuse it. Smooth out with fine steel wool or Scotch-brite pad
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Offline Imlhaas
« Reply #5 on: April 11, 2020, 02:25:30 PM »
Here is another picture- It is hard to photograph.  I did clean it up, you can feel imperfection with your nail, but not deep or sharp pits.
  • PA
Offline kjott
« Reply #6 on: April 11, 2020, 02:28:03 PM »
I took a chance and reused it. The bike is still in assembly-mode, and therefore not tested to see if I did the rigth thing  icon_cheers
  • 86' K100RS
86' K100RS
Offline kjott
« Reply #7 on: April 11, 2020, 02:34:17 PM »
I filled the imperfections with superglue and smooted it that way. Dont know if thats a great solution over tlme... guess the answer will apear after startup :)
  • 86' K100RS
86' K100RS
Offline volador
  • NEEDS MORE CHROME
« Reply #8 on: April 11, 2020, 03:26:11 PM »
Bravo ingenious use of superglue!
  • NYC NY
Offline volador
  • NEEDS MORE CHROME
« Reply #9 on: April 11, 2020, 03:30:58 PM »
Looks good reuse without fear
let us know how is works out
  • NYC NY
Offline Imlhaas
« Reply #10 on: April 11, 2020, 06:48:26 PM »
Put it back together drove it about 25 miles no leaks.  I had been getting about 4 drops of oil when I would stop and a wet oil pan.
  • PA
Offline volador
  • NEEDS MORE CHROME
« Reply #11 on: April 12, 2020, 12:59:29 PM »
You use any sealant on the mating surfaces?
  • NYC NY
Offline Imlhaas
« Reply #12 on: April 12, 2020, 05:24:59 PM »
I used Three Bond 1207b for the gasket material pump to engine and cover to pump.  I was surprised how easy it was to work with.  Put about 50 more miles on it today and found a bit of a drop at the weep hole, not enough to drop off and none on the oil pan.  Not sure if it was from the assembly grease or seeping, but I can live with that.
  • PA
