Author Topic: Help identifying a wire.  (Read 4568 times)
Offline Xero
« on: December 19, 2019, 07:20:05 PM »
Hi,
This must have come loose at one point and was found under the bike. Trying to figure out what this is exactly an where it came from. Pictures attached.
Thanks!
  • Toronto
  • 1990 K75RT, 2018 G310R
Re: Help identifying a wire.
« Reply #1 on: December 19, 2019, 08:55:24 PM »
Not to be flip here, but what doesn't work?  That would give you a clue.
« Reply #2 on: December 19, 2019, 10:05:27 PM »
Based upon the colors, for a K75RT, the only circuit I found with violet/white identification is for the choke lamp, from the inst cluster to the 2-pin connector of the switch.
Offline Xero
« Reply #3 on: December 19, 2019, 10:12:45 PM »
It looks more like violet(purple?)/yellow in person. But ill check out your idea. thank you.
  • Toronto
Offline Xero
« Reply #4 on: December 19, 2019, 10:13:52 PM »
Unfortunately there is so many things not working right now it's hard to pinpoint a problem. :(
most problems are instruments and lights related, also fuel pump doesnt seem to work.
  • Toronto
« Reply #5 on: December 20, 2019, 12:18:23 AM »
It looks more like violet(purple?)/yellow in person. . . .
Do you have a wiring diagram? Here is another possibility.
Put the year of your moto's manufacture in the Bikes: line of your Profile.
Offline Xero
« Reply #6 on: December 20, 2019, 08:33:52 PM »
I checked. Fan cable is there. So it's not that.
  • Toronto
Offline daveson
« Reply #7 on: December 20, 2019, 09:17:25 PM »
Is it violet/yellow, yellow/violet or something else? I'm guessing you have some optional extras.  What's the history of the bike?
The hazards are yellow/violet, but normally soldered to the switch.
  • Victoria, Australia
« Reply #8 on: December 20, 2019, 11:42:30 PM »
Odd for a wire to fall off if it's connected to anything.  Could it be an extension to the fan or something somebody decided not to use and left  precipitously dangling in the bowels of the bike?
Offline volador
  • NEEDS MORE CHROME
« Reply #9 on: December 21, 2019, 06:08:37 PM »
Extra fan? OE fan upgraded?
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Offline TommyT
  • New Brick Owner
« Reply #10 on: December 21, 2019, 08:05:03 PM »
OR an extension chord for the fan? Having just remove a fan, there is not much spare wire under the gas tank to unplug the wire to remove the radiator.
  • Olive NY
  • 1990 K75RT (RS), 1991 K100 16V
