Author Topic: K 75c Fork Springs  (Read 5688 times)
Offline ed3541
K 75c Fork Springs
« on: October 24, 2019, 10:18:36 AM »
Hi,
I have a 1995 K75c with squishy forks. A mechanic supposedly rebuilt my forks but the fluid leaked-out on to my brakes. I'm wondering if I can install fork springs in both tubes (like my old K75s). Does anybody know what parts I'm gonna need to put springs in both forks?
thanx,
Ed
  • Boca Raton, Florida
  • '92 K75s '95 K75 '85 FYK100
Re: K 75c Fork Springs
« Reply #1 on: October 24, 2019, 10:43:27 AM »
The K75C's last year of production was 1990. If yours is a 1995, it isn't a C-model.
A 1995 K75 should be equipped with a Showa fork unless the entire assembly had been swapped with an earlier model. The Showa tubes have external diameters of 41mm. The internal parts of both the left and right Showa tubes are identical. There already are springs in both tubes. First, determine the size of the tubes.
Your fork is squishy likely because there is little fluid in it. Did the fluid leak from the seals around the tube? Your mechanic might have used aftermarket seals. Original equipment seals are preferred.
  • 1995 K75 89,000 miles
Offline ed3541
« Reply #2 on: October 24, 2019, 01:59:10 PM »
Thanx Laitch,
I'm gonna get some OEM seals.
Ed
« Reply #3 on: October 24, 2019, 02:38:29 PM »
Take a close look at those tubes, ed. If they are pitted where they enter the lower tube, they are likely to make any seal leak.
« Reply #4 on: October 24, 2019, 04:32:30 PM »
To extend the life of your seals pack heavy silicone grease between the seal and the dust cover. It stops road crud from getting to the seals and probably keeps them lubed and flexible. Change the grease occasionally more often in dusty conditions. I changed the seals on my brick when I first got it over 20+ years ago.
« Reply #5 on: October 25, 2019, 07:06:58 PM »
Headlight isn't K75.  Probably isn't a K75S because those had 3 spoke wheels.  That would make it likely to be a chopped up RT.
If I remember right, the RT had longer travel softer forks than the other models, and I think they used a couple more ounces of oil as well.  If they weren't filled properly, I could see them being pretty soft and squishy.  Brake dive on my K75RT can be pretty alarming at times even when filled with the correct amount of fluid.
« Reply #6 on: October 25, 2019, 07:48:31 PM »
It's been cut up, missing rear cowl. Hard to say what it started out as.  Didn't RT's have the radiator hose outside the crankcase cover?  Or am I just getting senile?
Offline Past-my-Prime
« Reply #7 on: October 25, 2019, 08:22:56 PM »
Mine's an RT and the radiator hose goes through the fairing, not through the crankcase cover.
« Reply #8 on: October 25, 2019, 09:13:11 PM »
It's got 75s mirrors with the more streamlined back. And early 75s's did have the eight spoke wheels. What's on the compliance plate?
Offline volador
  • NEEDS MORE CHROME
« Reply #9 on: October 25, 2019, 10:51:00 PM »
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Offline volador
  • NEEDS MORE CHROME
« Reply #10 on: October 26, 2019, 10:26:08 AM »
  • NYC NY
« Reply #11 on: October 26, 2019, 10:48:08 AM »
'95 may or may not have 50A alternator
A 1995 original K75 will have the 50A alternator but like any used moto. parts might have been swapped along the line. ed needs to run the last seven digits of both his motos' VINs through the realoem VIN checker to determine what the motos might have been originally.
Offline ed3541
« Reply #12 on: October 26, 2019, 01:08:28 PM »
Yes I did the Vin# search and determined that it is a K75 not a K75c
thanx,
Ed
