Author Topic: $48 FPR and Cross Referencing  (Read 16073 times)
Offline 1ockdown
« on: October 22, 2019, 10:03:57 AM »
Just thought I'd share my finding as I haven't seen anyone post this before, and if it was, sorry in advance. I've been looking into replacing my FPR for some time now, but refused to pay the OEM fee. I've seen other sites that charge a lesser amount, but I thought I'd do some research and cross reference some part numbers and such. This led me to finding http://partsplusecat.com/. Click the Cross reference Tab, enter the part number and hit search. It will show other part numbers and parts that match and you can even get details about the part. This is the site that Autozone uses to cross reference parts for you in store.
For Example, the OEM Bosch FPR part number is # 0 280 160 200. I hit search and resulting part numbers on the right hand column are PR400 and 158-0073.
 If you click either of those, it will show images of the part,
* chrome_10022I6qO7.png (28.94 kB . 768x478 - viewed 712 times),
attributes
* chrome_voe0LESd5l.png (49.8 kB . 768x423 - viewed 664 times),
and automotives they fit for
* chrome_Lw4TJj14XP.png (50.93 kB . 768x397 - viewed 698 times)
Cross referencing part #'s PR400 and 158-0073 led to a slew of other options. Checking out the pictures even showed me that the Beck Arnley FPR produced slightly better manufacturing
* chrome_10022I6qO7.png (28.94 kB . 768x478 - viewed 712 times).
So basically, here is a $48 FPR from amazon https://www.amazon.com/Beck-Arnley-158-0073-Injection-Pressure/dp/B000CB03EA
* chrome_nwjoytfxcM.png (23.04 kB . 768x295 - viewed 654 times)
  • My garage in New York
  • 1994 K75S ABS
Offline volador
  • NEEDS MORE CHROME
Re: $48 FPR and Cross Referencing
« Reply #1 on: October 22, 2019, 10:41:52 AM »
Nice work just added to my order
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Offline 1ockdown
« Reply #2 on: October 22, 2019, 10:43:25 AM »
Thanks!  Nice to see a local bricker.
  • 1994 K75S ABS
Offline 1ockdown
« Reply #3 on: October 22, 2019, 11:13:34 AM »
Johnny, I have yet to install it, it's in the mail (158-0073). When I get it, I'll let you know. Is there an issue with parts that look like other parts, but dont function properly? My understanding was that FI systems between i think 60-90 were all similar, especially among jaguar, VW, Porsche.
  • 1994 K75S ABS
Offline SDCR john
« Reply #4 on: October 22, 2019, 11:16:36 AM »
1ockdown, Is the FPR a consumable maintenance item, or are you changing it due to a malfunction?
 Just curious, as I have a 49K mile K75, which most likely has the original FPR.
1994 BMW K75S Dakar Yellow #0154446
1983 Moto Guzzi 850 Le Mans
2000 BMW R1100 RS
Bucks County Pa.
Offline 1ockdown
« Reply #5 on: October 22, 2019, 11:18:57 AM »
I was changing it on suspected malfunction, I'm not original owner and I don't know the full history of the bike. its 25 years old and has 9k miles. With our FPR being the bellow vacuum type, I suspect sitting too long may have injured it. I wouldnt call it a regular maintenance item. Also, I just enjoy going out on a whim to find information.
  • 1994 K75S ABS
« Reply #6 on: October 22, 2019, 03:53:39 PM »
Mine still has the original at 200,000 miles
« Reply #7 on: October 23, 2019, 12:51:15 PM »
What was stopping you from running a pressure test—CBB disorder?
  • 1995 K75 89,000 miles
Offline 1ockdown
« Reply #8 on: October 23, 2019, 01:42:03 PM »
Well for one I don’t have a pressure gauge. When I squeeze the line between the fpr and end of the rail I can romp on the throttle with no issue whatsoever. I followed a post from a few years ago with a similar issue. I’m holding off on installing the new fpr until I know for certain it’s the problem. I found it cheap enough to have for a bit and run more tests and have it for when And if I need it. If I don’t need it, then it’s going back. I more or less made the post to share the cross referencing platform I’ve been using.
  • 1994 K75S ABS
« Reply #9 on: October 23, 2019, 01:49:32 PM »
Well, AutoZone, NAPA and perhaps other parts vendors will loan all types of specialized equipment to customers at no cost. A deposit comprising the cost of the gauge is made by the customer using a credit card then a refund to the card account is made on return of the equipment. I've been loaned bearing pullers, gauges and other costly equipment several times with no problems. Inquire locally. You are, after all, located at the hub of the world.
Offline 1ockdown
« Reply #10 on: October 24, 2019, 07:57:50 AM »
I don't know why I didn't think about that. I'll do that!!!
  • 1994 K75S ABS
Offline 1ockdown
« Reply #11 on: October 24, 2019, 12:11:37 PM »
Did what Laitch suggested, dont know why I forgot that AutoZone lends out equipment. Came out to $162 w/ Tax fully refundable upon return. Doing this process taught me that, correct me if wrong, the hose from regulator to tank is a bleed off hose and bleeds off pressure higher than 38ish psi, and in my case, sat next to 0-2psi. Tank to rail was in 36psi +/-2 range, and rail to regulator was 36psi +/-2 range. Gauge jiggles a bit. So I don't need the regulator I bought and will return it.
  • 1994 K75S ABS
« Reply #12 on: October 24, 2019, 01:14:32 PM »
thats badd juu juu...
I read somewhere sacrificing a laying hen might stall the consequences—maybe it was in the Haynes manual.
Offline 1ockdown
« Reply #13 on: October 24, 2019, 04:02:19 PM »
Hell if the OE one breaks then I'll have something to fix 😀😀. Now to finish fabricating the rear new rear end
  • 1994 K75S ABS
« Reply #14 on: October 24, 2019, 04:39:39 PM »
The biggest concern with FPR failure is the diaphragm can leak allowing fuel to be drawn into the vacuum line. This can lead to a Hydraulic lock resulting in a bent conrod and other nasty things.
« Reply #15 on: October 24, 2019, 05:23:50 PM »
The biggest concern with FPR failure is the diaphragm can leak allowing fuel to be drawn into the vacuum line. .
Happily, inspection for leakage is a simple process.
Offline riots100
« Reply #16 on: October 24, 2019, 07:41:29 PM »
Pull the FPR vacuum line from the throttle body.  If fuel drips out, you have a leak.  Don't ask me how I know, suffice it to say that rods were bent.
  • Los Angeles, CA
BDJ
« Reply #17 on: October 24, 2019, 08:10:55 PM »
Exactly like this. :-)
