Author Topic: You Want 3d You Gotts It ×  (Read 52612 times)
« on: October 16, 2019, 10:11:17 AM »
please start 3d threads on this board...
and if there are existing poasts abouts 3d please poast the link here in this thread if you want the poast moved to this board...
enjoy...
Offline bmwcyclist
Re: You Want 3d You Gotts It ×
« Reply #1 on: November 21, 2019, 10:41:23 PM »
I would love to have some brick bits to print.
Here are a few things on thingiverse.
Beta clutch tool
https://www.thingiverse.com/thing:959712
tragkorb repair
https://www.thingiverse.com/thing:2183440
Seat / tank rubber cover replacement clamp
https://www.thingiverse.com/thing:3544051
Turn signal button
https://www.thingiverse.com/thing:3240741
Battery tray mount Yuasa TTz10s
https://www.thingiverse.com/thing:3585049
  • Batavia Oh
  • K75 1990, K75RT 1995
Offline djaysan
  • Proud owner of a K1100 RS 93'
« Reply #2 on: December 10, 2019, 03:16:43 PM »
https://bike3dparts.alainorset.com/
I think this website has pretty all about it ;)
  • Poland
  • F800R, K1100 RS
Proud owner of K1100RS 93' after selling my F800R 11'
« Reply #3 on: March 09, 2020, 11:01:28 AM »
I'm going to try the sidecase hinges next time the ones I have break. Those OEM hinges are crap.
Offline bmwcyclist
« Reply #4 on: March 09, 2020, 11:04:56 AM »
Let me know how that goes.
I assume you are going to print using ABS?
  • Batavia Oh
Offline djaysan
« Reply #5 on: April 14, 2020, 02:34:04 AM »
Hello guys , found another website sharing some key 3d part models such as speedo cases for motoscope and even airbox grid :
https://www.fiveaces.hk/index.php/support/bmw-3d-parts
  • Poland
  • F800R, K1100 RS
Offline triplek
"Every time you criticize my grammar, I like you a little bit fewer."
1995 K75 RTP, 1995 K75 RT, 1993 K75, two K75 frames, 1 fully assembled engine from airbox to exhaust tip and enough fairings and  parts to build another K. Soon.  ;)
« Reply #7 on: March 20, 2022, 06:39:14 PM »
Never had an issue with mine.  The only time they broke is when I low-sided on sand into a ditch and they broke probably by design which saved the case.
They are $8.50 ea.
« Reply #8 on: March 20, 2022, 06:58:19 PM »
I use aluminum piano hinges.
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/pianohinge/pianohinge.htm
« Reply #9 on: June 01, 2022, 09:10:22 AM »
I never did it probably because it wasn't going to work with the filaments I have lying around. ABS and PETG are to hard and brittle. You'd have to use nylon or vinyl filaments and spending $30 bucks for a roll of filament that might or might not work is kind of not a good cost/benefit ratio. Plus, they'd need lots of supports due to the overhang that would be a bitch to remove or you'd need water soluble supports and a multi-extruder printer which I don't have.
« Reply #10 on: June 01, 2022, 12:26:52 PM »
Those hinges are polypropylene and molded so they can flex at the pivot point.  I would suspect that they would not be very successful if 3D printed.  At $8.50 a pop for the factory part they're one item I wouldn't hesitate getting from BMW.
« Reply #11 on: June 01, 2022, 12:41:39 PM »
BTW; If you're ever out touring and a hinge breaks then 2 or 3 layers of duct tape makes for an adequate temporary repair. BTDT.
« Reply #12 on: June 01, 2022, 01:47:09 PM »
Or you can carry a spare hinge.
They take up virtually no space and will guarantee that you will never have one break.  If necessary, they can be changed in 5 minutes on the side of the road with no tools.
Offline sj2000
« Reply #13 on: January 17, 2024, 09:15:42 PM »
  • Parker, USA
