Author Topic: Foot rest brackets compatibility  (Read 5815 times)
Offline Chri5
  • Buy it - Break it - Rebuild it!
« on: October 06, 2019, 08:01:44 PM »
I would like to change my stock foot peg brackets to later ones as the first gen brackets are fugly. Does any one know what brackets are compatible with 2v k's i know i cant use k1 but will the k75 or later 4v brackets will fit without modification?
  • United Kingdom
  • K100RS
Yamaha FZ6n-s2 electric conversion(Electric motor 240nm of instant torque)
Kawasaki Z750R
85 BMW K100RS
Buy - Break - Rebuild - Repeat!
Re: Foot rest brackets compatibility
« Reply #1 on: October 06, 2019, 08:55:31 PM »
you have done a full strip... last i heard you said you were gonna sort of cafe racer it but not quite...
poast up some current photos...
have you looked at the fische to see what fits...
Offline Chri5
« Reply #2 on: October 06, 2019, 10:21:33 PM »
Well johnny the cafes out there is what drew me to the K. With plans to do that. But ive fallen in love with the thing and now i want to just modernise it with as much orginial parts as possible. So ive spit and polished, stripped the fairing upgraded the lights to led and plan to redesign the tail and lots of carbon fibre ( my day job) parts i also plan to rehoop but only by maybe 4 or 5 inchs max as i bought this to do mileage and want to have my orginal tragkorbs and 22litre top box fitable with a carbon brackets
Heres a pic as its my daily transport so its slow going
I havent checked fische dont really kbow what im doing to properly check so i thought i would throw it on here
  • United Kingdom
  • K100RS
Kawasaki Z750R
85 BMW K100RS
Offline volador
  • NEEDS MORE CHROME
« Reply #3 on: October 06, 2019, 11:44:59 PM »
Wow you may have the Iconic Soggz Krauser Rear Rack.
Carbon fibre on a 1985, can't wait to see it!
https://shop.maxbmw.com/fiche/PartsFiche.aspx
Start there and can put in the last 7 digits of your VIN or pick your model from list
1) go to category 46-Frame, Fairing, Cases and scroll down to diagram for footpegs, etc...
2) pick a part number say 46711457237 PLATE LEFT BLACK RIB UNPAINTED
3) go here https://shop.maxbmw.com/fiche/PartsSearch.aspx  put that part number in the search field
4) your results will be what moto models that specific part will be found on/"should" fit on/interchangeable with
Caveat get a second opinion doing the same here https://www.realoem.com/bmw/enUS/select
Good luck with your moto
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
« Reply #4 on: October 06, 2019, 11:45:53 PM »
most cafe racers make custom pegs with custom gear shift and custom rear brake actuators to match their perceived ergos and their hawt as f look...
or they paint the oe camo so nobody can see them...
Offline Chri5
« Reply #5 on: October 07, 2019, 12:32:10 AM »
Yep i do have the soggz rack must be a UK thing. I dont want custom pegs they are crap one person over priced junk that bend if the bike goes over. no bench seat will be found on my motor either i like to ride and walk afterwards.
 my concern with part look up is will my current rear master cylinder And gear shift linkage work, will my brake switch fit (which i believe they changed later)
If some one has done it and can let me know there experience it would be a great help
  • United Kingdom
  • K100RS
Kawasaki Z750R
85 BMW K100RS
Offline volador
  • NEEDS MORE CHROME
« Reply #6 on: October 07, 2019, 01:19:41 AM »
Which brake switch type do you have?
Service bulletin for newer brake switch   https://shop.maxbmw.com/fiche/NotesParts/61311459588_1.pdf
  • NYC NY
Offline Chri5
« Reply #7 on: October 07, 2019, 04:46:57 PM »
I currently have the old plunger type
  • United Kingdom
  • K100RS
Kawasaki Z750R
85 BMW K100RS
« Reply #8 on: October 07, 2019, 04:56:30 PM »
Do you want to learn how to check a fiche?
Offline Chri5
« Reply #9 on: October 07, 2019, 05:05:30 PM »
Yes i do i assume voladors instruction is correct but any tips and tricks ill take in ernest
  • United Kingdom
  • K100RS
Kawasaki Z750R
85 BMW K100RS
« Reply #10 on: October 07, 2019, 05:22:29 PM »
There are no tips or tricks; it's drudgery but it makes you self-reliant.
« Reply #11 on: October 07, 2019, 08:42:09 PM »
(maxbmw doesnt seem to want to load)
does the lack of rubber mount make much difference in the vibrations felt through the pegs
Hi admin ill accept the imminent ban on this account too.
MAX is sometimes slow to load but it gets there eventually.
I don't believe the rubber mounts make much difference because they seem to have been abandoned on later models.
As far as accepting a ban goes, you don't have any choice. :-) Just go with the flow, learn the site features, provide part numbers and photos, and review your posts for clarity before you publish them.
Offline volador
  • NEEDS MORE CHROME
« Reply #12 on: October 08, 2019, 12:37:16 PM »
Another option is coat them in black
  • NYC NY
