Author Topic: new from PA  (Read 6071 times)
Offline overeasy
new from PA
« on: September 24, 2019, 09:54:03 AM »
New here from south central PA.  A coworker has been trying to sell me his 85 K100 RS for the past eight years and it finally happened.  It's an early 85 he bought new and rode all over Europe as his only transportation while stationed in Spain. It has 65,000 miles on it.  The last few years it's only been used once a year to go get an inspection sticker and whatever repairs it needed at the dealer. (new rear shock, new Metzelers) but it was stored inside, at least.
This past year it wouldn't start. So now it's getting the fuel pump and isolator, etc.   The PO put a Pichler fairing on it as soon as he brought it home, and the original Alaska Blue fairing was sealed in a box from that day until a few weeks ago when I opened it.  I'm going to try to sell it to to offset some of the parts costs.
I'm not a new rider - I've had everything from Ninja 250s to Concours 1000.   Currently I have this Bimmer not-yet-back-together, an '09 Rebel 250 (also blue) that I made into a bobber, and a 71 Yamaha 175 Enduro.  I'm the second owner of all three, the last two I got from my late father-in-law.    I'm a ride-to-work kinda guy, and also for pleasure. And the occasional road trip now that I again have something with more horsepower than my riding mower.
Gonna do some site searching to find out what fuel injectors I should buy, and try to find a value for a basically-NOS fairing.  Mine's got an 8/84 build date and I'm finding some parts changed design for the later 85s.
  • Pennsylvania
  • 85 K100 RS
Re: new from PA
« Reply #1 on: September 24, 2019, 09:59:48 AM »
Welcome, overeasy!
Post some photos of your moto using the Attachments and other options feature under the reply box. You won't be able to preview your images; they show up when you post them. It's an adventure using that feature.
Re: new from PA
« Reply #2 on: September 24, 2019, 11:52:27 AM »
those Pichler's are sharp looking on K's, love to see some pics.  Amazing how many 85's keep popping up.
Offline volador
  • NEEDS MORE CHROME
Re: new from PA
« Reply #3 on: September 24, 2019, 04:43:03 PM »
Welcome. Alot of good moes and info here.
Notable differences of the pre-85/86 K100 are the seat pan design with matching tail cowl section, the water/oil pump design changed, throttle cable design and fuel tank/fuel level sender/fuel return check valve.
Your 8/84 may have the European "hotter" cams known as "Finest Year K"
http://www.motobrick.com/index.php/topic,3653.msg56782.html#msg56782
https://forums.bmwmoa.org/showthread.php?4534-Why-is-the-85-K100-the-quot-Finest-Year-K-quot&s=66f149b3cadea44550d51fbf0b9ee793&p=42512&viewfull=1#post42512
The pre-1985/86 has molded pillion handles as part of the seat pan, metal or plastic seat pan.
Post-1985/86 removed handles from seat pan and added handles to the tail cowl section.
http://www.bmwkbike.dx.am/CLseats/kbikeseats.htm
Water Pump
pre-1986-87? original design old style impeller 11411461177
Superseded by 11412325850 design change the shaft with gear Z=32 teeth, shaft- 11411461183
Superseded by 11417676366 same shaft with gear Z=32 teeth
latest design 11517676371 design change shaft with gear Z=19 teeth, shaft- 11411461793
Throttle cables have 2 versions and lower brackets. Cable lengths vary with handlebars.
#1 version- have a adjustment sleeve approx. halfway down length
2nd version black plastic collar at the lower end or a white plastic collar
Pre-1985 fuel tank has a rear mounting tab later removed.
Early fuel lever sender is a thermistor type later is a float type.
http://www.kforum-tech.com/how-to/Modification%20for%20early%20gas%20tank.htm
Good Riding
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Offline overeasy
Re: new from PA
« Reply #4 on: September 24, 2019, 11:07:14 PM »
The PO said the one mechanic said this bike made more power than any K100 he's ridden. I thought maybe it was just a story but the hotter cam explanation might be it.  It was a US-spec bike - bought at Frank's in Manheim, PA (original keychain included) It went to Europe when the PO was deployed to Spain after he bought it.
  • Pennsylvania
  • 85 K100 RS
Offline ScooterNSticks
Re: new from PA
« Reply #5 on: September 24, 2019, 11:28:29 PM »
Welcome to Motobrick!  Lots of great support, information and fun here.
  • Boalsburg, PA
  • 1992 BMW K75, 2006 Vespa GTS 250ie
My Blog: Scooter in the Sticks
https://scooterinthesticks.com
Offline volador
  • NEEDS MORE CHROME
Re: new from PA
« Reply #6 on: September 25, 2019, 02:04:12 AM »
Check condition of the inside of fuel tank. Lowest portions are prone to corrosion when moto is left sitting for some time.
Not many 85 tanks left around in this condition
ebay 85 Tank
  • NYC NY
Offline overeasy
Re: new from PA
« Reply #7 on: September 25, 2019, 10:41:10 PM »
ebay 85 Tank
Mines a little smashed on the top, and that's even the right color.  Aside from black chunks of vibration damper inside, mine appears to be stable and shiny. No sign of corrosion when peeking in the filler, at least. Thank you for all the wisdom. I have a lot to learn.
  • Pennsylvania
  • 85 K100 RS
