Author Topic: Headlight bulb conversion  (Read 11125 times)
Re: Headlight bulb conversion
« Reply #25 on: September 22, 2019, 08:05:39 AM »
Ok, yes, I’m no good at electrics . . .
I'm no good at interpersonal communication but I don't let that stop me. Sometimes it can be shocking, just like electrics. You've already replaced the bulb so you know if you would have room to stuff an extra socket and wiring in the shell. If you can, get the H4 option without the posilocks. At the end of the day, installing a relay helps lengthen the life of the switch. How much it lengthens that life is anybody's guess. It also allows bulbs to burn brighter because it reduces electrical resistance. That also means bulbs will burn out slightly sooner.
I'm not constrained by the lack of a relay. I see as much as I need to see with what I've got. Furthermore, I have no desire to dazzle drivers and animals into a confused stop in the roadway in front of me by using high power lights nor do I have a desire to blaze a pathway ahead of me tempting nearsighted animals in rut into using it to cross in front of me. I use a 60/55 halogen bulb. I replace the six dollar bulb every two years. I haven't had a bulb burn out after thousands of miles of pothole riding, but I always have spare bulbs with me and changing a headlight bulb on my moto takes the removal of one Phillips head screw. I ride at night on highways and back roads. I enjoy it.
Maybe I'll install a relay before my light switch fails me on a mountain road bend but right now, I'm on a highway to Hell.
« Reply #26 on: September 22, 2019, 09:56:12 AM »
The basic installation is pretty easy.
Attach the two ring terminals to the battery at the back end.
At the front end unplug the connector on your headlight bulb and plug it into the mating connector on the the Eastern Beaver harness.
Then attach the female connector on the EB harness to the headlight bulb.
Make sure the harness doesn't interfere with steering.
Done.
I would recommend the harness for headlight shell and the connection for the running lights on the HI beam.  During daylight you can run them and be seen.  At night, you will have the extra light with the hi beam, and when you dim for oncoming traffic you will kill the driving lights just leaving the lo beam that won't blind oncoming drivers.  That's how I do mine now.
Offline Soggz
« Reply #27 on: September 22, 2019, 03:26:56 PM »
Done.
Ok, thanks. That sort of makes it easier to understand. I just have to find one now.
  • Down in Selwood Forest
Offline Soggz
« Reply #28 on: September 23, 2019, 09:05:23 AM »
Done.
hi. These?
« Reply #29 on: September 23, 2019, 09:38:06 AM »
That's the one, get the version with the driving lights on with the hi beam.
Offline Soggz
« Reply #30 on: September 23, 2019, 10:26:43 AM »
ok, thanks all.
