Author Topic: Electrical  (Read 3139 times)
Electrical
« on: September 09, 2019, 04:05:01 PM »
dielectric grease or conductive grease on brick electric connectors...
im saying conductive... what brand you use...
Re: Electrical
« Reply #1 on: September 09, 2019, 05:40:55 PM »
Loctite 8801
Re: Electrical
« Reply #2 on: September 09, 2019, 05:55:05 PM »
I use Dielectric, non-conductive. Prevents stray current from leaking, but more importantly it prevents air from getting to the metal terminals and causing corrosion/oxidation.
Offline stokester
Re: Electrical
« Reply #3 on: September 09, 2019, 06:31:22 PM »
Depends...
Dielectric grease (silicone) is good for bulbs and large connectors to keep the elements out but dielectric is an insulator which can present problems on some connections.
When I worked at the Chevy shop we used dielectric lubricant to help prevent fretting and moisture intrusion on fine pin connectors.  The only product I know of that actually enhances connectivity is Stabilant which is insanely expensive.
  • Yorktown Virginia
