Author Topic: Turn signal whack revisited  (Read 55649 times)
Offline beemuker
Re: Turn signal whack revisited
« Reply #100 on: September 29, 2019, 01:02:47 PM »
I don't know why you haven't gone in the switches.  One screw holds them on the bars, and you don't have to remove them to get to the guts for cleaning.
???? I did open them up and spray with contact cleaner, but to get at the contacts there is a small philips screw that you have to remove to get at the guts and I wasn't sure that small parts wouldn't fall out that I would have difficulty putting back together. Am I being to cautious?
  • Panama City, FL
« Reply #101 on: September 29, 2019, 02:40:13 PM »
You opened the switches and sprayed them with contact cleaner.  Maybe that's why the whack has gone.  You might be lucky.
Offline beemuker
« Reply #102 on: September 29, 2019, 02:52:24 PM »
not too, as it's come and gone and come and gone since I did it.
  • Panama City, FL
« Reply #103 on: September 29, 2019, 03:03:39 PM »
OK, go in deeper.  If wiggling the cancel switch fixes the whack, that might point to the problem.
Do you normally use the cancel switch, or leave it to the self cancel feature?
Offline beemuker
« Reply #104 on: September 29, 2019, 03:30:04 PM »
wiggling anything does not fix it. My flashers do not go off without the cancel switch, unless they are not working, then they all flash as long as the button is depressed.
  • Panama City, FL
« Reply #105 on: September 29, 2019, 03:56:00 PM »
How do the indicators work if you unplug the cancel switch? The indicators should then work, but of course you can't cancel manually then.
Offline beemuker
« Reply #106 on: September 29, 2019, 06:06:43 PM »
where/how do you unplug it?
  • Panama City, FL
« Reply #107 on: September 29, 2019, 06:11:00 PM »
... but of course you can't cancel manually then.
They can be cancelled manually. A light ball peen hammer will shut them down with a couple of whacks. Find a deal on replacement lenses and bulbs or just keep going straight. There's a lot of enjoyment right out in front of us.
« Reply #108 on: September 29, 2019, 06:59:00 PM »
 Looking at an old post, you actually fixed the whack by cleaning the earth's under the tank. Clean them again,  clean them better, let them dry and reassemble.
The cancel plug is with the right hand plug under the tank.  A single wire,  brown/white on one side,  brown on the other.
With my brick on the centre stand,  at~1100rpm, in second gear,  the indicators turned off automatically at 50 seconds.
Offline beemuker
« Reply #109 on: September 29, 2019, 08:11:57 PM »
how do I know I actually fixed it, it comes and goes?but it couldn't hurt, thanks.
  • Panama City, FL
« Reply #110 on: September 29, 2019, 10:40:01 PM »
There are a few options.
Fuses.
Clean the earth's and connections again (maybe it was half fixed because it was half cleaned)
Cleaning the switches.
Test the earth's to the flasher unit.
Unplug the cancel switch and leave it unplugged.
If cancel switch unplugged = no whack,
cancel switch plugged in = whack,
that's the whack.
« Reply #111 on: September 29, 2019, 11:40:24 PM »
There's already way too much whack in this thread.
« Reply #112 on: September 30, 2019, 03:06:01 AM »
Has your loom worn from the black plastic, vertical infill panel, on the left side opening for the forks? Mine has.
You should be able to see it, without removing anything.
* IMG_9336.JPG (45.62 kB . 768x576 - viewed 461 times)
« Reply #113 on: September 30, 2019, 08:29:45 AM »
The thread's title invites it. Go with the flow.
Offline beemuker
« Reply #114 on: October 01, 2019, 09:37:18 AM »
The flashers are currently not whacky, I'm going to wait until they re-whack so I can tell if what I do to unwhack is really unwhacking .
  • Panama City, FL
« Reply #115 on: October 01, 2019, 09:58:17 AM »
Can you summarize what you've done and at what point the whacky became the unwhacked?
Offline beemuker
« Reply #116 on: March 01, 2020, 02:55:33 PM »
finally bit the bullet after trying everything [almost]  ,  purchased a used "Tast-warnbl.-Relais" , 1 459 224 , otherwise known as the flasher relay on fleabay, and guess what, flasher whack cured. Just wanted to update for those who need resolution.
  • Panama City, FL
Offline beemuker
« Reply #117 on: March 01, 2020, 02:58:05 PM »
there are only 2 people who know what is causing that whack....
me and inge k...
wish you had just told me, but then I would never have seen all those wires.
  • Panama City, FL
« Reply #118 on: March 01, 2020, 05:28:43 PM »
Thanks for caring.  icon_cheers
Offline beemuker
« Reply #119 on: March 01, 2020, 06:11:26 PM »
your welcome. maybe it will help some hapless motorbricker in the future
  • Panama City, FL
« Reply #120 on: March 02, 2020, 06:52:21 AM »
That's the idea behind all this, for sure, although it does run amok occasionally.  :laughing4-giggles:
