Author Topic: Fuel from exhaust - no start whackness.  (Read 29486 times)
Offline DJEwen
« on: August 01, 2019, 12:47:57 PM »
Hello,
I’ve just gone out to take my Motobrick for a ride and she didn’t start, after a few attempts I could smell fuel, I then realised fuel is steadily dripping from the exhaust when start button is pressed.
I went to grab my multimeter and the trouble starting guide, dropped the multimeter and smashed the screen... I’ve ordered a new one.
In the meantime I pulled the vacuum hose that connects between throttle body #4 and the bottom of the fuel pressure regulator to check for a presence of fuel, it was dry so I suspect there isn’t a diagram leak in the FPR.
Is there anything else I can do in the interim without a multi meter?
  • Scotland
Re: Fuel from exhaust - no start whackness.
« Reply #1 on: August 01, 2019, 01:21:49 PM »
Disconnect, reconnect the electronic fuel injector control unit plug; remove the fuel pump fuse and crank to dry off the plugs or remove them, dry them lovingly and individually, replace them then try starting with no throttle.
Offline DJEwen
« Reply #2 on: August 01, 2019, 02:09:25 PM »
Done as you said, no change. The plugs weren’t overly wet but I pulled them all, cleaned and gapped them. I cranked the bike with the plugs out and the pump and injectors disconnected to clear the inlets and it looked like #2 and #4 weren’t sparking (difficult to see as I’m in my own) so potentially a cool issue? Why are the injectors remaining open and pouring fuel in? Video of fuel leak below.
  • Scotland
« Reply #3 on: August 01, 2019, 02:53:41 PM »
I went to grab my multimeter and the trouble starting guide, ...
Because one or more is stuck open and there is enough fuel pressure to force fuel through the aperture.
Consider not using that trouble starting guide. It's starting too much trouble—reaching out and affecting coordination and gravity.   :laughing4-giggles:
« Reply #4 on: August 01, 2019, 03:02:10 PM »
If you have a timing light, ground it, put the inductive clamp around each suspected plug's wire, crank the starer and see if it lights.
« Reply #5 on: August 01, 2019, 03:55:55 PM »
Over fuelling can also be caused by a faulty temperature sensor or a bad connection. Try starting with the fuel pump fuse #6 marked Krafftstoppe temoved. It should start on the residual fuel left in the combustion chamber, as the engine starts to die ram the fuse back in. A bit of manipulation of the throttle is required. It can be done with one person but two is better.
Offline Soggz
« Reply #6 on: August 05, 2019, 06:28:23 AM »
I had this problem. A new temp sender fixed it.
  • Down in Selwood Forest
Offline Gr-Racing
« Reply #7 on: August 05, 2019, 12:35:12 PM »
had the same problem and like other said, new temp sensor was my fix
  • GA
  • K75
Offline DJEwen
« Reply #8 on: August 05, 2019, 02:56:27 PM »
Thanks for the input, everyone. Is there a way of testing the switch before I rip it out and replace it?
  • Scotland
« Reply #9 on: August 05, 2019, 03:39:07 PM »
You'll need a multimeter. Go to this post the open the document in the link at the bottom of the post. Three-quarters of the way through it you'll find an explanation of how to test various circuits on the L-Jetronic plug. There is an illustration of the plug with the circuits labeled. You'll be checking Pin #10—the coolant temperature sensor—to see how its values correspond with those on the table in that section.
Offline Soggz
« Reply #10 on: August 05, 2019, 04:19:55 PM »
Or just replace it.
Offline DJEwen
« Reply #11 on: August 05, 2019, 05:09:41 PM »
Thanks, Laitch. My new multimeter should arrive tomorrow.
Or just replace it.
I’ve ordered one so it’s getting replaced, but I still want to know for myself that this was the only issue.
  • Scotland
Offline Soggz
« Reply #12 on: August 06, 2019, 02:13:30 AM »
with those symptoms, and the advice from the good people on here, there’s not much else to go wrong. If the new one dosnt work, get the injectors professionally cleaned. It cost me £50.00 over here.
Offline DJEwen
« Reply #13 on: August 06, 2019, 03:57:52 AM »
I agree but what I’ve learned with this bike is that there’s always something new going on. I’ll take pleasure completing the test, at least I’ll know how it’s done point forward. Every day is a school day.
That’s not a bad price, I was looking at replacing them altogether with 4 hole ones but may go down the cleaning route. I have 4 spare so can send them off.
  • Scotland
Offline Soggz
« Reply #14 on: August 06, 2019, 07:30:19 AM »
tbh, if the injectors are working ok, there’s no need to replace them, from what I’ve read. They either work, or they don’t, apparently. 4 hole ones don’t make a lot of difference. People think they do, but they are new with clean parts. Mine are old, but have been cleaned and work great. Save your money, and replace some of the crap bmw nuts and bolts and electrical connections, instead!
Offline DJEwen
« Reply #15 on: August 06, 2019, 02:45:27 PM »
You’re not the first to mention the non improvement in the 4 hole ones, I’ll give them a miss and get a set cleaned.
Anyway, when I built the bike it was a piece of cake to remove the original temperature sensor as I had the stand pipe off the block and everything stripped down. Different story tonight, I’m not sure if there’s a massively expensive one time use BMW tool for doing this but the design is shit. No space for a spanner, too long a plug for a normal socket, no space for a long reach, no space for purchase with pipe grips etc. I ended up hack sawing the plug off then removing with a standard socket. New temp sender is en route.
  • Scotland
« Reply #16 on: August 06, 2019, 03:29:52 PM »
The only confirmed difference is increased fuel consumption and a larger chance of them blocking. I am yet to see a dyno comparison between 1 hole versus 4 hole, no company selling the 4 hole ones have posted a dyno report to my knowledge. I would love to see one and wouldn't mind being proved wrong. The difference often quoted is I felt an increase in performance when I fitted the 4 hole injectors over my dirty 1 hole injectors. While on a mission to cure my 75 of occasional backfiring on over run, I built my own cleaner and test rig. Once cleaned and flow checked they proved to be the final piece in the backfiring puzzle. A by product proved to be an increase in seat of pants performance.
« Reply #17 on: August 06, 2019, 05:41:47 PM »
Just buy a couple battles of Techron and put half a bottle per tank for 3-4 tanks of high rpm riding over a 2-3 week period.  You should start to notice a difference around the second tank.  This has worked on two k100's for me.
No reason why cleaning your injectors has to be dull.
Offline DJEwen
« Reply #18 on: August 08, 2019, 05:26:17 AM »
That's effectively what I've done, Gryph.
  • Scotland
« Reply #19 on: August 08, 2019, 02:25:24 PM »
No space for a spanner, too long a plug for a normal socket, no space for a long reach, no space for purchase with pipe grips etc. I ended up hacks Seong the plug off then removing with a standard socket. New temp sender is en route.
You didn't go after it by removing the air box first and fetching it from behind the radiator?
Offline DJEwen
« Reply #20 on: August 08, 2019, 04:37:54 PM »
Is that the procedure? I removed the radiator first, the standpipe is straight upright and would have the same access issues from either side presumably? It’s the close proximity of the upper barb that’s the issue.
  • Scotland
« Reply #21 on: August 08, 2019, 06:42:26 PM »
Is that the procedure? would have the same access issues from either side presumably?
Presumably?  :nono2: There seemed to be enough room in there when I removed the air box.
Here's mlytle's take.
* Screen Shot 2019-08-08 at 6.40.10 PM.png (59.76 kB . 768x470 - viewed 984 times)
Offline DJEwen
« Reply #22 on: August 09, 2019, 07:12:10 AM »
Hmm, I'd still argue the access to the fitting is a poor design as the above the barb is the problem, however, removing the air box is a much lesser job than dropping the coolant and removing the radiator! I'm happy however to see that my coolant was immaculate at least  :laughing4-giggles:
  • Scotland
Offline natalena
« Reply #23 on: August 09, 2019, 09:07:33 AM »
Just received Techron from Amazon Prime at $7.99/20oz bottles. Seemed to be a reasonable price for an in-vitro cure, and prophylactic.
  • MST
Offline volador
  • NEEDS MORE CHROME
« Reply #24 on: August 09, 2019, 09:31:05 AM »
IMHO that Techron stuff looks, smells, tastes, feels just like Kerosene
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
