Author Topic: Rear wheel fit on K75  (Read 5006 times)
Offline Xero
« on: July 27, 2019, 07:28:43 PM »
Hi all,
Will 2007 K1200GT rear wheel (17″ x 5.50″) fit 1990 K75T?
Thank you.
  • Toronto
  • 1990 K75RT, 2018 G310R
Re: Rear wheel fit on K75
« Reply #1 on: July 27, 2019, 08:42:27 PM »
 :welcome
yes... that is if you gotts fabrication skills... special tools... machine shop...
Offline Xero
« Reply #2 on: July 27, 2019, 09:03:48 PM »
Thank you johnny.
So if I am understanding correctly easiest wider wheel to fit on K75 would be 3 spoke 4.5x18?
  • Toronto
« Reply #3 on: July 27, 2019, 09:12:49 PM »
did you click the link...
Offline Xero
« Reply #4 on: July 27, 2019, 09:43:47 PM »
I did, it's little confusing to understand for a beginner. I don't even know what oilhead is. sorry.
  • Toronto
« Reply #5 on: July 27, 2019, 09:50:18 PM »
rodger that... we need to see your wheels so we know what is on that k75... they could be oe... they could not be oe...
poast up photos of your moto here... make sure we can see your wheels...
proally one of these two...
snowflake
* wheelsnowflake.jpg (31.59 kB . 400x300 - viewed 534 times)
3spoke
* wheel3spoke.jpg (10.41 kB . 259x194 - viewed 519 times)
also... what is the part number of the k1200gt wheel... you gotts a photo of it... poast it here...
Offline Xero
« Reply #6 on: July 27, 2019, 10:08:43 PM »
Yes mine is exactly like that snowflake.
k1200gt wheel photos attached. Unfortunately I am not sure about part number right this moment but will ask seller to provide.
* s-l1600 (2).jpg (44.36 kB . 768x576 - viewed 529 times)
* s-l1600 (1).jpg (53.62 kB . 768x576 - viewed 473 times)
  • Toronto
« Reply #7 on: July 27, 2019, 10:13:14 PM »
so this is on the 75...
* wheelsnowflake.jpg (31.59 kB . 400x300 - viewed 526 times)
this is off the 1200...
* wheelk1200.jpg (53.62 kB . 768x576 - viewed 478 times)
is that right...
Offline Xero
« Reply #8 on: July 27, 2019, 10:15:51 PM »
Yes. That is correct.
  • Toronto
« Reply #9 on: July 27, 2019, 10:19:37 PM »
the k75 hub is 4 lug bolts and 1 center bolt...
the 1200 hub is 5 lug bolts and 0 center bolt...
so you would have to fabricate an adapter... before making an adapter put a measuring take acrosst the swing arm at the leading edge of the rear tior... that will tell you how wide a tior you can run without machining a new swing arm...
so... measure that and report back here...
Offline Xero
« Reply #10 on: July 27, 2019, 10:21:00 PM »
Thank you johnny! This is very helpful.
  • Toronto
« Reply #11 on: July 27, 2019, 10:25:08 PM »
i am here to unwhack the whack... canadican or other...
1) need that swing arm measurement...
2) need to know what tior size is on the k75 snowflake wheel...
3) need to know what tior size you are gonna put on the 1200 wheel...
find that out and report back here...
Offline Xero
« Reply #12 on: July 27, 2019, 10:26:49 PM »
Will do. Cheers :)
 :freebizzaro
  • Toronto
« Reply #13 on: July 28, 2019, 04:35:02 AM »
Thousands of insufferable IT geeks have made it possible to understand what an oilhead is simply by typing the word oilhead into Google's search window of your device's web browser. Don't miss the opportunity.
Offline bocutter Ed
« Reply #14 on: July 28, 2019, 07:27:14 AM »
Welcome to the forum ...
  • Toronto, Canada
« Reply #15 on: July 28, 2019, 07:33:32 AM »
 :bbhorns:
