Author Topic: bucks, runs on maybe 2 cylinders and then back to normal  (Read 3501 times)
Offline zipster68
« on: July 17, 2019, 04:30:06 PM »
Hi Brickers,
I've got a new (intermittent) problem on my 86 K100.  Bike starts easy, idles great and after maybe 10-15 minutes bucks a couple times and acts like it's running on 2 cylinders, for maybe 15 seconds (doesn't stall out).  Then runs perfectly normal.  This has happened maybe 3 times.  Doesn't appear related to wetness, temperature.  I've got fresh gas in there and the tank looks clean.  I've got a very new looking coil pack that I've swapped in a couple years ago.
Possible issues...
fuel filter
injectors
throttle pos'n sensor
Looking for suggestions if you've got any.
Cheers,
Ray
  • Ferndale, Michigan
  • 1986 K100RS, 1977 naked Goldwing, 1975 Yamaha RD350 smoker, 1978 Vespa P200, 1980 Lambretta Jet 200
Offline natalena
Re: bucks, runs on maybe 2 cylinders and then back to normal
« Reply #1 on: July 17, 2019, 04:44:52 PM »
You left out the 4-pin ;)
If it runs great after the sporadic episodes, I'd be guessing electrical.
  • MST
« Reply #2 on: July 17, 2019, 05:05:07 PM »
Check and clean the four-pin pump connector.
Check all the interior fuel lines for clamp tightness.
Clean and tighten the battery negative ground on the transmission.
Check the battery connections for tightness.
Check the ground connections on the backbone frame member under the tank.
Change the fuel filter if you don't know how old it is, or if it's a Fram filter.
There's more after this. :giggles
  • 1995 K75 89,000 miles
« Reply #3 on: July 17, 2019, 08:50:40 PM »
Temporary wonky on two cylinders, maybe check coil connections.
Offline zipster68
« Reply #4 on: July 17, 2019, 09:35:46 PM »
Don at Detroit BMW says water in the gas and/or tank.  My cap is installed backwards and that isn't good either for water.  I'm gonna pump all of that gas out, mop the bottom and start fresh.
« Reply #5 on: July 17, 2019, 09:48:02 PM »
Don't forget to check/clean the multi-pin plug on the ignition control module..
1995 K1100LT 0302044
1997 K1100LT 0302488 (R.I.P.)
Offline zipster68
« Reply #6 on: July 18, 2019, 09:23:32 AM »
I'll check it.  Where the hell is it?
-Ray
« Reply #7 on: July 18, 2019, 12:48:54 PM »
Ignition control unit is at the left arrow; its plug is at the right arrow.
