Author Topic: FS: New Jersey Nice 1992 K75s 13K mi  (Read 5901 times)
Offline volador
  • NEEDS MORE CHROME
« on: July 14, 2019, 11:07:19 PM »
I'm seeing New Jersey double K75s's in Red this evening
Nicer eBay Red 1992 K75s
Clutch spline lube job?
Someone is getting a good deal
Good Day
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Offline mdk_mdk
Re: FS: New Jersey Nice 1992 K75s 13K mi
« Reply #1 on: July 22, 2019, 06:56:18 PM »
Relisted at $2250: https://www.ebay.com/itm/133120065147?ViewItem=&vxp=mtr&item=133120065147
I'm local to this bike if anyone wants an inspection.
  • Ringoes NJ
  • 1990 K75
« Reply #2 on: July 22, 2019, 10:09:28 PM »
Clutch jerks when letting out in 1st gear no noise in the trans or engine. Dealer thinks it’s the clutch disc springs as trans is quiet.
I have acquired . . . semi new trans (<8k).
That's a used transmission, not a semi-new one. How hard it was used in those 8k miles is unknown.
There are no springs on a K75 clutch disc.
Something else is going on with the clutch, its linkage or the transmission so that's one dealer to avoid.
The price is approaching reasonableness. There are definitely bargaining points with this one.
Offline SDCR john
« Reply #3 on: July 23, 2019, 12:20:41 PM »
What causes the paint to blister near the gas filler, fumes?
I am relatively new to K bikes, so please explain Cylinder Synchronizing??
1994 BMW K75S Dakar Yellow #0154446
1983 Moto Guzzi 850 Le Mans
2000 BMW R1100 RS
Bucks County Pa.
« Reply #4 on: July 23, 2019, 01:02:42 PM »
What causes the paint to blister near the gas filler, fumes? I am relatively new to K bikes, so please explain Cylinder Synchronizing??
The ad is a cornucopia of displaced jargon and whack theory.
Faulty fuel tank ventilation allows the escape of excessive fuel fumes from the tank to degrade paint around the tank opening, especially if the paint used is not a fume-resistant type.
K motos aren't exotic; they're car engines tipped onto their sides. How new is relatively new—new as compared with time on Planet Earth, time finding copulation opportunities in saloons, time learning to spiral-cut radishes with a paring knife?
You'd need to to ask the vendor what is meant by cylinder synchronization. Throttle body synchronization is a tuneup procedure to balance air intake among the throttle bodies as a means for smooth idle and optimal performance of the engine.
Offline SDCR john
« Reply #5 on: July 23, 2019, 01:59:27 PM »
I mentioned that I am new to K's, as it relates to that specific description, cylinder synchronization. Thought it might be a special K bike procedure, that only those with the secret handshake would know.
Thanks.
2000 BMW R1100 RS
Bucks County Pa.
