Author Topic: Disc "float"  (Read 3085 times)
Offline BlitzenGruv
Disc "float"
« on: July 11, 2019, 08:22:02 PM »
This is my first experience with 'floating' discs. Just seems like they feel loose. How do I know?
I can't find any spec in the manual, much less how to measure 'float.'
OK, I read the post on replacing the buffers. Still no info on how much slop is acceptable. The clock on mine says 36K miles. I guess they're all right.
  • Crossville, TN
Re: Disc "float"
« Reply #1 on: July 12, 2019, 01:59:05 AM »
Axial (push/pull) play is acceptable; radial (rotational) play isn't desirable but if the brakes are stopping well under load, ride on. If bothered by noise, earplugs—as usual—are the solution.
Offline BlitzenGruv
Re: Disc "float"
« Reply #2 on: July 13, 2019, 12:17:26 AM »
Thanks,
Not too much play, as I said it's just new to me. Everything else I have has fixed rotors.
Brakes stop well at speed, they just feel a little weird at slow speeds. Maybe that's the ABS?
Still quiet, though.
  • Crossville, TN
Re: Disc "float"
« Reply #3 on: July 13, 2019, 05:56:48 AM »
. . . they just feel a little weird at slow speeds. Maybe that's the ABS?
At low speed hard braking you might be feeling them pulsate. At high speed hard braking you don't feel that because you're preoccupied by your watching your life flash before you.
Offline alabrew
Re: Disc "float"
« Reply #4 on: July 13, 2019, 01:04:22 PM »
When I got my 4v, the rotors were pretty clanky and had a lot of float. Several bobbins were also mangled. I replaced the rotor bobbins, very simple to do, and all is much better.
  • Birmingham, Alabama
  • 1985 K100, 1991 K100RS
Also:
2005 K1200LT
1979 R65
