Author Topic: Red triangle light  (Read 6011 times)
Offline Soggz
Red triangle light
« on: July 02, 2019, 02:40:58 PM »
Stays on, never used to. Why’s this? Someone said it was a bulb check light?
All the bulbs are fine. It dosnt go off if I hit both brakes, either.
Any suggestions on why, please.
Thanks.
  • Down in Selwood Forest
Offline John Lang
  • John Lang
Re: Red triangle light
« Reply #1 on: July 02, 2019, 02:54:18 PM »
Haynes (p.219): for UK models the warning light remaining on when the lights are turned off means the fault is in the brake light circuit.
  • Ottawa, ON Canada
Offline Soggz
« Reply #2 on: July 02, 2019, 02:57:44 PM »
Thanks. All bulbs are fine. Brake light dosnt come on if handlebar lever is depressed, but does when footbrake is pressed. Could it be the switch on the lever?
Offline John Lang
  • John Lang
« Reply #3 on: July 02, 2019, 03:10:15 PM »
Very likely. The warning light is testing the brake switches as well as the bulbs. You might be able to disassemble the front brake switch to test/clean it. Cannot hurt to check wiring continuity and bulb monitoring unit connections.
  • Ottawa, ON Canada
Offline Soggz
« Reply #4 on: July 02, 2019, 05:44:14 PM »
Ok,thanks John.
« Reply #5 on: July 02, 2019, 07:10:17 PM »
Both brake switches need to work to extinguish the light.
Offline John Lang
  • John Lang
« Reply #6 on: July 02, 2019, 07:32:15 PM »
I re-read your message. The foot brake switch is the more likely suspect, although the UK version is slightly different that the North American so who knows? It's a gritty neighbourhood around the rear brake pedal so I'd begin cleaning there. As Gryph said, BOTH switches have to work in order that the warning light goes off.
  • Ottawa, ON Canada
Offline Soggz
« Reply #7 on: July 03, 2019, 02:23:46 AM »
Thanks all. How would I test them?
Just swop them over?
Offline John Lang
  • John Lang
« Reply #8 on: July 03, 2019, 08:01:37 AM »
The brake switches are not interchangeable but each connects to the harness by means of a 2-prong plug. Suggest you decouple these, apply multimeter probes to the switch side of the plug and check for continuity when the the brake is applied.
  • Ottawa, ON Canada
« Reply #9 on: July 03, 2019, 09:30:52 AM »
As long as I've owned my K, the bulb monitor light has turned on and off at all kinds of random moments. But I have never observed a problem with my brake light function.
For years I've been telling myself to just pull the bulb the next time I have the breadbox opened up.
« Reply #10 on: July 03, 2019, 09:37:09 AM »
Attached is some general and installation information from the mothership concerning these switches.
« Reply #11 on: July 03, 2019, 09:59:06 AM »
Check the rear brake switch first.  As mentioned earlier it's in a rough operating environment.  The activating linkage can get road crap in it, messing with the action, not to mention corrosion on the connections.
I had a problem with the rear brake switch on my K100.  It is just a standard industrial micro-switch, and I bought a replacement from Radio Shack for something like $2.
Offline Soggz
« Reply #12 on: July 03, 2019, 03:28:33 PM »
Hi All. Rear brake lights working. I’m guessing the front switch has had it.I will test it tomorrow when I have a little time to myself.
Thanks for all the reply’s.
Offline Soggz
« Reply #13 on: July 05, 2019, 11:16:13 AM »
Yup...
Switch...
