Author Topic: BMW K1100RS YSS Damper  (Read 5271 times)
Offline volador
  • NEEDS MORE CHROME
« on: June 05, 2019, 07:36:26 PM »
Looky here, after all this malarkey of dampers, YSS and bins
Soggz you need a K1100rs! Check your spring rate
Ebay BMW K1100RS YSS Damper
Looks like the right size box
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Re: BMW K1100RS YSS Damper
« Reply #1 on: June 05, 2019, 09:21:09 PM »
The K1100 has a longer shock absorber than the K75.
Offline Soggz
« Reply #2 on: June 06, 2019, 02:06:44 PM »
mines shorter. 35cm.
  • Down in Selwood Forest
Offline volador
  • NEEDS MORE CHROME
« Reply #3 on: June 06, 2019, 02:23:58 PM »
Stock OEM Damper length
K75, K100 (monolever)- 360mm
K100 4V, K1100- 390mm
  • NYC NY
Offline Soggz
« Reply #4 on: June 06, 2019, 04:45:17 PM »
are they measured from end to end, or from the top and bottom hole centres?
Offline volador
  • NEEDS MORE CHROME
« Reply #5 on: June 06, 2019, 05:04:39 PM »
Measured center hole to center hole
Those are general values
Your damper length is your preference
  • NYC NY
Offline Soggz
« Reply #6 on: June 06, 2019, 06:05:06 PM »
Ok, thank you.
