Author Topic: To Start or not to start. That is the Question  (Read 2842 times)
Offline Skunky
« on: June 04, 2019, 11:07:07 PM »
Morning Brickers
I have a question with regard to a starting issue.
I keep my bike on a trickle charger. When I start her she starts and runs fine. When I stop and go to start again the starter does not turn. I also lose my lights indicators horn etc.
I tried the reverse sprag thingy and it sometimes helps.
If I leave it on the trickle charger for a while it will start again. I'm not sure whether the issue is with the starter or alternator. The Battery light goes off when the engine starts.
I understand that the Load Shed Relay will take the power off the ancillary systems when the starter is pressed. Am I right in thinking that if the Starter brushes are worn you get a poor grounding and the Circuit to the LSR will be open therefore leaving everything off ?.
Thanks
Skunky
  • Derby GB
  • BMW K100lt BMWK1100lt
90 K100lt 97 K1100lt
Honda FMX650 Honda CB400F
Re: To Start or not to start. That is the Question
« Reply #1 on: June 04, 2019, 11:18:16 PM »
Pull the starter and clean and measure the brushes, should take you about an hour. Carbon build up does funny things on Bricks.
Offline Skunky
« Reply #2 on: June 04, 2019, 11:19:49 PM »
Thanks Martin. I'll do it over the next couple of days.
  • Derby GB
Offline volador
  • NEEDS MORE CHROME
« Reply #3 on: June 05, 2019, 07:42:06 AM »
The load shed relay which has the headlight and some other stuff connected grounds to the hot brush of the starter. If the starter is not energized this provides a path to ground for the relay coil, thus providing current to the headlight, etc.
However, when the starter button is depressed +12v is applied to the hot brush. The load shed relay coil now has +12v applied to both ends of the coil - thus no ground. So the relay turns the headlight and stuff off until the starter button is released.
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
