Author Topic: WTB: fuel level sender for a k75  (Read 10635 times)
Offline fatallightning
« on: May 31, 2019, 12:38:47 PM »
You know the part, you know why I need it. Anyone holding?
  • NY
  • 87 k75 87 TW200 76 CB360 82 SR250 02 WR426 82 KZ750
Re: WTB: fuel level sender for a k75
« Reply #1 on: May 31, 2019, 02:06:55 PM »
What you needs depends on the year of your moto's fuel tank. Does the part have a float or not?
« Reply #2 on: May 31, 2019, 07:25:55 PM »
He's got 87 k75 in the signature so we'd have to assume it's a float type.
« Reply #3 on: May 31, 2019, 07:28:55 PM »
. . . we'd have to assume it's a float type.
Considering parts are swapped on these motos with regularity and confirmation is a simple process, assumption seems as pointless here as anywhere else.
Offline volador
  • NEEDS MORE CHROME
« Reply #4 on: June 01, 2019, 02:12:25 AM »
I bet you a Latte there's a metal rod thingy with a large ping pong ball stuck on the end inside OP's fuel tank
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
« Reply #5 on: June 01, 2019, 08:54:57 AM »
You're on! rbm can hold the PayPal notes, and fatality can supply photos.
« Reply #6 on: June 01, 2019, 10:05:58 AM »
If you need the ping pong ball on the coat hanger thingie I have one.
« Reply #7 on: June 01, 2019, 01:12:56 PM »
Dually.
Offline volador
  • NEEDS MORE CHROME
« Reply #8 on: June 01, 2019, 01:30:34 PM »
Dually.
Are you holding a Physics webinar?
  • NYC NY
« Reply #9 on: June 01, 2019, 01:48:28 PM »
No. That was a pie plate I just put into the sink. Update your LIDAR.
« Reply #10 on: June 01, 2019, 03:18:56 PM »
My bad for not clarifying, I need this guy. Part number is 62 16 1 459 565. I'm having intermittent fuel pump issues and I'm pretty sure it's at the fuel level sender pass through.
  • NY
Offline volador
  • NEEDS MORE CHROME
« Reply #11 on: June 01, 2019, 03:37:31 PM »
MMmmm I love pie. I'll have a piece with my Latte
  • NYC NY
« Reply #12 on: June 01, 2019, 03:41:07 PM »
I would check the 4-pin connector first.
« Reply #13 on: June 01, 2019, 03:47:37 PM »
OK. To me it looks like a marshmallow, and a medium-sized one at that. If rbm says it's a large ping pong ball instead of a marshmallow, send me your PayPal address.
:1a:
« Reply #14 on: June 01, 2019, 05:04:04 PM »
Gave em a good wiggle and they've also already been replaced with 4 pin trailer style connectors. I should pull the float and check it for continuity and resistance.
  • NY
Offline volador
  • NEEDS MORE CHROME
« Reply #15 on: June 01, 2019, 05:52:17 PM »
  4 pin configuration on the male end of the Petrol Gauge Level Sender
1.Brown-is ground continuity to the larger diameter ring terminal
2.Green-is 12V continuity to the smaller diameter ring terminal
3.Yellow-is fuel level
4.White-is 4 litre reserve indicator
Remove the ring terminals from the fuel pump to perform the continuity test
  • NYC NY
Offline volador
  • NEEDS MORE CHROME
« Reply #16 on: June 01, 2019, 08:54:32 PM »
:1a:
We don't need to bug rbm. We're good. Cheers
* CappNap.JPG (47.21 kB . 768x514 - viewed 1100 times)
  • NYC NY
« Reply #17 on: June 01, 2019, 09:09:26 PM »
We're good. Cheers
It's settled then. You owe me a latte. I want one with a fried egg floating in it like yours. I'll be in touch. :giggles
