Author Topic: RT deflector yellowed  (Read 7842 times)
Offline schrocketeer
« on: May 22, 2019, 12:03:28 PM »
The deflector strip on my '85 RT has yellowed quite a bit more than the rest of the windshield. Is there any treatment to de-yellow it?
I've seen new deflector strips for $75, or the aftermarket total windshield replacements for $300'ish, but those both seem expensive.
Any suggestions?
  • North Alabama
  • 1985 K100RT very original
Ken
Re: RT deflector yellowed
« Reply #1 on: May 22, 2019, 03:09:22 PM »
« Reply #2 on: May 22, 2019, 06:53:52 PM »
Sometimes clear plastic can be de yellowed with cut and polish,  wouldn't hurt to try it. I've done it on headlights for roadworthies, but I go El cheapo now with nifty or something similar.
« Reply #3 on: May 22, 2019, 07:28:21 PM »
I use Meguiars PlastX and a 6" bench grinder fitted with a 6'' loose cotton buffing wheel that I only used on plastic. I have a separate buff for metal. The buff speeds up the process but requires a gentle approach with light pressure and the object needs to be kept moving. A slower safer method is to do it by hand. I have been told not to use silicone spray products on acrylic as it can cause fatigue cracks in the plastic.
