Author Topic: Suggested paint for the black, injector cover  (Read 7833 times)
Offline SDCR john
« on: May 08, 2019, 01:17:25 PM »
As I had mentioned earlier, I recently bought a 94 K75 S. The bike has about 46K, and is in generally nice shape. I would like to paint the black injector shield, due to a slight color fade, or scratch. The shield appears to be made of some type of plastic. Anyone have a good rattlecan paint suggestion? Thanks.
1994 BMW K75S Dakar Yellow #0154446
1983 Moto Guzzi 850 Le Mans
2000 BMW R1100 RS
Bucks County Pa.
Offline mw074
Re: Suggested paint for the black, injector cover
« Reply #1 on: May 08, 2019, 01:33:04 PM »
Krylon 1613 Semi Flat Black.
  • Michigan
Offline SDCR john
« Reply #2 on: May 08, 2019, 01:47:28 PM »
Great, I assume that that is a very close match to the OEM color? my intent is to keep it looking as stock as possible.
Thanks.
2000 BMW R1100 RS
Bucks County Pa.
Offline mw074
« Reply #3 on: May 08, 2019, 02:49:51 PM »
Very good match.
  • Michigan
Offline SDCR john
« Reply #4 on: May 08, 2019, 03:38:04 PM »
Thank you for the recommendation.
2000 BMW R1100 RS
Bucks County Pa.
« Reply #5 on: May 08, 2019, 04:15:57 PM »
If you want to do a good job do the following prep:
Wash with dish detergent, dry
Wipe down with clean rag soaked with rubbing alcohol
Scuff with 600 grit wet or dry(dull the surface)
Spray with adhesion promoter(follow directions on the can) don't trust the paint to stick to flexible plastic without this stuff
Prime with light gray hi build sanding primer(follow directions on the can)
Carefully sand with 320, avoid sanding through the primer
Wipe again with rubbing alcohol
Apply 3-4 light coats of the finish(follow directions for recoat and drying time time)
« Reply #6 on: May 08, 2019, 05:06:18 PM »
Not sure what an injector cover is on a K75S, neither of mine has one.
Offline SDCR john
« Reply #7 on: May 08, 2019, 05:49:11 PM »
In the attached pic, Its the black cover that is just above the left valve cover. Apparently, it was an OEM part on the K75 S Dakar Yellow.
2000 BMW R1100 RS
Bucks County Pa.
Offline SDCR john
« Reply #8 on: May 08, 2019, 05:58:04 PM »
This looks like the "right" away... thanks. :2thumbup:
2000 BMW R1100 RS
Bucks County Pa.
« Reply #9 on: May 08, 2019, 06:01:01 PM »
The injector cover was a part not exclusive to your model though. I have one on my plebeian K75. Onlookers are awed by its effect on left-side engine aesthetics. :giggles
« Reply #10 on: May 08, 2019, 06:06:19 PM »
Interesting, not on mine.
Offline mw074
« Reply #11 on: May 08, 2019, 06:15:06 PM »
I have a new one for a K100 with no hardware if anybody is interested. Email me.
  • Michigan
« Reply #12 on: May 08, 2019, 06:27:24 PM »
The cover would be a hinderance in Queensland's summer. The only way I finally cured the vaporizing fuel rail problem was to fit a reflective heat shield under the rail.
Offline mw074
« Reply #13 on: May 08, 2019, 06:29:38 PM »
These were made by CC products in California. Not sure if they are still available. I never had any heat related issues in the US.
  • Michigan
« Reply #14 on: May 08, 2019, 07:42:10 PM »
We get 35C-40C+ but what makes it worse is being stuck in slow moving traffic. The return line to the tank used to soften up and crimp over. A better quality hose a Unicoil and the heat shield have finally fixed the vaporization.
« Reply #15 on: May 08, 2019, 09:38:48 PM »
I had that CC injector cover long ago, it got stress cracks and didn't really serve any purpose other than hiding some bits.  Even rarer is the CC spark plug cover, replaces the BMW plate with an aluminum air scoop to cool the plugs.  Their hype at the time was that this was a hot spot on the K engine.  There was some truth to this, a motorcycle magazine had done a series of heat imaging photos of various engines and the spark plug area of the K bike's was distinctly warmer, but nowhere near as hot as most spots of an air cooled engine.
Offline mw074
« Reply #16 on: May 09, 2019, 12:21:12 AM »
I had a couple of the plug covers also. I may still have one. I will dig through some boxes. If I still do, I will post a pic.
  • Michigan
« Reply #17 on: May 09, 2019, 08:01:50 AM »
So that cover was an aftermarket item; that explains why my Dakar Yeller 75S didn't have one.
Offline SDCR john
« Reply #18 on: May 09, 2019, 08:08:22 PM »
Speaking of the 1994 Dakar yellow K75 S, is there anything definitive regarding the actual production number of the these?
 The gentleman who sold me this, said that he had understood 100 yellow versions were imported in 1994.
2000 BMW R1100 RS
Bucks County Pa.
Offline Soggz
« Reply #19 on: May 28, 2019, 05:52:28 PM »
£25.00 Motobins.
  • Down in Selwood Forest
