Author Topic: Speedometer works, odometer doesn't...  (Read 15428 times)
Offline ws76133
  • After Reading This Forum I Will Be Forever Whack
« on: April 28, 2019, 04:10:10 AM »
Question:  The speedometer on my 1991 K75S still works fine, but this afternoon, the odometer and trip meter stopped.  I'll clean the speedo sensor on the final drive when I get home, but since the speedometer works, I'm not hopeful.
Any ideas?
  • United States
  • 1991 K75S
Re: Speedometer works, odometer doesn't...
« Reply #1 on: April 28, 2019, 04:28:12 AM »
A well known problem the gears on the odometer are literally made of cheese and crumble. New gears are available.
Offline TX brick
« Reply #2 on: April 28, 2019, 05:42:38 AM »
Overseas Speedometer in Austin, Tx does a good job if you decide to have it repaired. They did my 91 75RT.
Ron
91 K75RT
Belton Tx
« Reply #3 on: April 28, 2019, 09:23:50 AM »
They're not too hard to replace, just takes some patience.  Plenty of on line help.  http://www.odometergears.com/products/BMW/R+&+K+Motorcycles/42
Offline stokester
« Reply #4 on: April 28, 2019, 09:41:44 AM »
Agreed, there is plenty of info on this site and you'll find my post about visiting Jeff Caplan at Odometer Gears and pics of what your gears probably look like.
  • Yorktown Virginia
« Reply #5 on: April 28, 2019, 11:16:56 AM »
... the gears on the odometer are literally made of cheese and crumble.
Actually, mine were made of compressed applesauce.  The cheese ones were an upgrade.
Offline RobP
« Reply #6 on: April 29, 2019, 02:32:48 PM »
Quote
+1 on Overseas Speedometer if you decide to have someone else do it.  I had Rick replace the gears in my 1985 K100RS instrument cluster.  Great guy, and he stands behind his work.
  • Driftwood, TX
  • 1985 K100RS
Offline szabgab
« Reply #7 on: April 30, 2019, 03:22:09 PM »
Or you can get some newly fabricated ones from a Spanish guy.  Good place to stock up on some starter buttons too :)
http://www.hardtoptire.com/producto_en-hardtop.php?id=168&id_familia=104&id_catalogo=19
  • Budapest, Hungary
  • K75S 1985 model
Offline brichbk
« Reply #8 on: May 02, 2019, 12:15:08 AM »
Installed a new HFP-437 Fuel Pump I got for $42 on Amazon.  It's a direct replacement for the factory one.
  • Central Valley California
  • 1993 BMW K75RT // 1982 Honda Nighthawk 650sc
« Reply #9 on: May 02, 2019, 02:57:28 AM »
Any ideas?
To many of us, that probably would seem unsuitable for use as either an odometer or a speedometer.
« Reply #10 on: May 02, 2019, 09:56:00 AM »
you need gas to drive the odometer, (well, indirectly) so I will let it pass as relevent
« Reply #11 on: May 02, 2019, 11:38:51 AM »
:giggles
Offline TriSpark
« Reply #12 on: May 07, 2019, 08:21:07 PM »
Mine just did the same this week ! Guess I'll be making the repair soon.
  • Chattanooga TN
  • Red 1987 K75s
Offline ScooterNSticks
« Reply #13 on: August 24, 2019, 04:40:58 PM »
I filled my gas tank and reset the trip odometer.  About 28 miles along on a ride it stopped working along with the mileage odometer.  Reset it again and still neither working.  Speedometer is fine.   After bouncing along for another 10 miles on a rough road it begins to work and continued to work fine for the next 200 miles until I returned home.
Did some investigating here and found this post.  Contacted Overseas Speedometers in Austin, Texas and got a quote to replace the gears and such.
My question is -- How likely is it that the odometer will continue to work fine?  I can imagine why it stopped but not why it started again.
I really want to ride for awhile -- like until December when the weather gets cold and then pull the instrument cluster if something is not working.
Any experience of these things having a short hiccup and then function fine for another 40K miles?
  • Boalsburg, PA
  • 1992 BMW K75, 2006 Vespa GTS 250ie
My Blog: Scooter in the Sticks
https://scooterinthesticks.com
« Reply #14 on: August 24, 2019, 05:01:26 PM »
I knew a woman who smoked a pack of cigarettes a day and lived an active life until her early eighties when she killed herself with a derringer. I hope that helps.
« Reply #15 on: August 24, 2019, 05:12:08 PM »
Man, the cryptic nature of information here makes my brain itch as I attempt to decipher.  As far as I can make out, in 15 years I think I'm supposed to shoot myself.
I'll just keep riding it until it becomes annoying to not have an odometer.  They seem overrated.
  • Boalsburg, PA
« Reply #16 on: August 24, 2019, 05:20:25 PM »
They are overrated. Use an astrolabe instead. As long as you have a relatively accurate low fuel light and ability at dead reckoning, you're golden.
« Reply #17 on: August 24, 2019, 07:05:58 PM »
But where do you keep the charts??
The low fuel light comes on after about 100 miles.  I guess I keep track.
  • Boalsburg, PA
Offline stokester
« Reply #18 on: August 24, 2019, 07:24:06 PM »
<CUT>
<CUT>
I'm curious how much they ask to rebuild it.  It's not difficult and they are available with instructions as I posted previously.
The bike runs fine without updating the odometer, you'll just have to keep an eye on the fuel lamp.  On my '93 K75S the trip meter has never worked since I've owned it and when the odometer quit I dismantled the cluster. It was apparent the gears were shot for the odometer but I still could not figure out the failure in the trip meter and without a spare I did not want to take it too far.  I've used an inexpensive bicycle computer to keep track of the tank mileage since I've owned it and have replaced the gears.
  • Yorktown Virginia
« Reply #19 on: August 24, 2019, 07:29:17 PM »
You put them in the maritime version of City Cases—Nauti Cases.
With GPS and its swarm of attending apps, odometers and speedometers are quaint reminders of a simpler time—like Regal Beer cans and prophylactic machines that need change to be operated.
« Reply #20 on: August 24, 2019, 07:35:16 PM »
As long as the low fuel light works you should be okay.  If is comes on as you say at 100 miles, just figure on filling the tank within an hour and you should be good.
I suspect one of the drive gears for the tripmeter has lost a tooth.  If you are adventurous you can open the case and get at the odometer and make a repair in an evening.
« Reply #21 on: August 24, 2019, 08:38:27 PM »
They want $250 to repair the trip odometer and odometer.  Not sure how long they would have it.  And while they have it apart they'll fix the burned out illumination lights.
My biggest concern is monitoring the fuel.  If the trip odometer fails again I'll have to rely on the fuel light.  And I can use some app on my phone I suppose to track mileage.  Would like to have some rough idea of the total mileage.
  • Boalsburg, PA
« Reply #22 on: August 24, 2019, 08:40:09 PM »
So far I'm keeping the bike quaint.  No GPS, apps  or other electrical contraptions.  I still need to put three quarters in the ignition before I can ride the bike.
  • Boalsburg, PA
« Reply #23 on: August 24, 2019, 08:45:15 PM »
Riding it with protection is good policy.
« Reply #24 on: August 24, 2019, 08:55:57 PM »
I've looked at the detailed instructions that I could download from the the Odometergears site.  Not sure if they're too complicated for me or if I just would rather pay to have someone else do it.  Still sorting that out.
Things are different with this K75 than with my Vespa.  Riding through snow and salt for years with the scooter found me washing it once in the spring and the very, very occasional wax job every few years.  I basically maintained a rat scoot.  I've had the K75 for about a month and have washed and waxed it three times already.  It's like it's some high maintenance date.  The damn thing feels like it is aligning with horses and boats as a place to send money and time.  Oh well, I'm smitten.  It's a joy to ride.
  • Boalsburg, PA
