Hi Gents
So my super reliable K75RT has a intermittent electrical problem. Bear with me this might be a long post.
A few days back I head out on a ride and the battery light comes on but only half lit. This happens 4 or 5 times in the first 40 miles and then the bike shuts off for a couple of seconds but comes back on. I turn around, stop at a friends house for 45 minutes and ride home no problem.
The next day I put a voltmeter across my battery and go for a 6 mile ride. At first the voltage holds steady at 13.8v but then it starts jumping around, always lower as low as 11.9v I shut the bike off for 20 minutes, start it up and it holds voltage steady at 13.9v
Yesterday I pull the battery which is New, and pull the alternator brushes out, they look good and pull the ground wire and check it and it seems fine. While pulling the ECU plug I notice it was not snapped in tight. I put a voltmeter on the battery and ride 6 miles and It does not flinch, steady at 13.9v. I think it was the ECU plug and I fixed it yahoo.
I change my oils. I start the bike to fill the oil filter in my shop and after 15 seconds it shuts off and the Battery light is half lit. Dammit. After a few seconds like 3-5 the light comes on bright and it starts. Over the next 20 minutes I start the bike several times. Several times when I turn on the key the battery light is only half lit and the motor will not crank, then I wait a few seconds and the battery light comes on bright and it starts right up.
To all you electrical genius's out there please, what is causing this?
I got to get this fixed as the short season is on here
Thanks in advance!
Nick
