Author Topic: Exhaust collector  (Read 2224 times)
Offline JPaganel
Exhaust collector
« on: April 19, 2019, 02:39:20 PM »
I have a little bit of oil smoke on occasion if the bike has been parked for a while. This seems to be normal for all BMW bikes that have valves on the low side when on the sidestand. Not concerned about that.
When that happens, I am seeing some of it come out where the exhaust collector is bolted to the engine.
I have no running problems whatsoever, and it isn't  loud, so if it is an exhaust leak, it is a minor one.
So, is this something I should muck with?  If so, how? Try to tighten bolts, replace gaskets?
  • Minnesnowta
  • 1986 K100RT, 1996 R1100RS
Offline alabrew
Re: Exhaust collector
« Reply #1 on: April 19, 2019, 04:36:05 PM »
They ALL do that! =-}
Park on the center stand or hold the bike upright (or even tilted to the right) after you turn off the engine to allow the oil to drain back to the sump before putting it on the side stand.
  • Birmingham, Alabama
  • 1985 K100, 1991 K100RS
Also:
2005 K1200LT
1979 R65
« Reply #2 on: April 19, 2019, 05:15:04 PM »
To check for leaks I use a vacuum cleaner set to blow. You can also use a compressor but drop the pressure down. Do this on a cold engine.  Place a rag around the nozzle stick it in the exhaust outlet, there is no need for a tight seal. Spray all points that could possibly leak with a mixture of detergent & water out of a spray bottle. Any leaks will show as bubbles.
