Author Topic: K1100 Won't Crank  (Read 4069 times)
Offline k
K1100 Won't Crank
« on: April 07, 2019, 02:32:08 PM »
Battery is charged. Bike is in neutral with stand up. Makes a high-pitched whine when I hit the button, but the starter doesn't crank.
All solutions appreciated.
  • Indiana
Re: K1100 Won't Crank
« Reply #1 on: April 07, 2019, 03:07:17 PM »
1) when did it last run... 2) will it bump start... 3) did you back spin it... 4) take a video with sound and post it here so we can hear it... 5) could be starter spinning and not engaging or could be the sprag clutch needs a flush amoungst other things...
Offline k
« Reply #2 on: April 07, 2019, 05:14:57 PM »
Starter isn't spinning. Not a sprag issue, at least not yet.
Ran in November.
Flat here. No bump start.
Tried backspin, moving in gear, and trying to make the starter advance a degree.
  • Indiana
« Reply #3 on: April 07, 2019, 05:18:58 PM »
What happens with the lights(headlight, dash lights, etc...) when you hit the starter button.
1995 K1100LT 0302044
1997 K1100LT 0302488 (R.I.P.)
« Reply #4 on: April 07, 2019, 05:41:06 PM »
has it been on a tender over the winter... or did you install a new battery this spring... or what...
have you serviced the 4 pin...
fully charged... what voltage off and voltage when you hit button...
need audio...
Offline k
« Reply #5 on: April 07, 2019, 06:11:20 PM »
The battery's not the issue. I also tried jumper cables off a car.
Fuel pump spins but the starter doesn't.
  • Indiana
Offline k
« Reply #6 on: April 07, 2019, 07:17:03 PM »
Cranks fine. Starts fine. Runs fine. Idles fine.
Battery is toast.
  • Indiana
« Reply #7 on: April 07, 2019, 07:42:44 PM »
need clarity...
cranks fine... starts fine... runs fine... idles fine... you mean last november...
need that audio... and those voltages...
« Reply #8 on: April 07, 2019, 09:12:56 PM »
Cranks fine. Starts fine. Runs fine. Idles fine. Battery is toast.
These two quotes don't square. How did you start it?
Offline k
« Reply #9 on: April 08, 2019, 09:17:47 PM »
Conflicting battery readings. Used a jumper box, and it fired up almost immediately after being parked since November.
  • Indiana
