Author Topic: Can I Put 4V Speedo On 2V K100  (Read 3228 times)
« on: February 28, 2019, 12:04:27 PM »
Does anyone know if a speedo assembly for a 4V K1100 will work in a 2V K100 cluster.  Guy I know needs one, but the one I have is from a K1100.
I can see the scale is different, as well as the sweep angle.  Pulse rate from the final drive is the same, and the odometer is working with similar tire sizes.
I know the fuel lights are different, but that's all I can see as a potential problem.  Thinking I can swap the movement and faceplate keep the old lights.
thanks.
Offline bocutter Ed
Re: Can I Put 4V Speedo On 2V K100
« Reply #1 on: March 01, 2019, 10:55:18 AM »
I think I have a spare good working speedo
  • Toronto, Canada
« Reply #2 on: March 01, 2019, 10:57:04 AM »
Km or miles?
Offline szabgab
« Reply #3 on: March 01, 2019, 11:21:07 AM »
Km or miles?
Ed's will be miles I guess.  If km is needed I have a whole cluster,  I had other things to do,  so I did not put it up for sale as yet...   Clock is not working much,  as it is showing numbers in Klingonese and the lens is cracked,  but everything else works,  as it should...
  • Budapest, Hungary
  • K75S 1985 model
Offline bocutter Ed
« Reply #4 on: March 01, 2019, 03:18:53 PM »
Km or miles?
I think I got it from California ... so both.
  • Toronto, Canada
