Author Topic: Café for a k1100  (Read 44775 times)
Offline DJEwen
Re: Café for a k1100
« Reply #75 on: March 05, 2019, 04:00:28 AM »
Is that a cafe4euro collector? Did it fit pretty snug for you? Mine doesn’t seem to fit snugly and leaks pretty bad.
You need to coat the inside of the collector with exhaust putty, coat the pipes up too then I mated up the surfaces, tightened the exhaust to its final position, wiped away any excess then initially heated it dry with the heat gun before running the bike to make sure I didn’t blow any out on start which would remove the seal - works perfect.
  • Scotland
Offline boardjnky4
« Reply #76 on: March 05, 2019, 06:36:18 AM »
You rock! Thanks for the tip
  • North America
  • K1100LT
« Reply #77 on: March 05, 2019, 07:36:29 AM »
How about starting a thread of your own with photos of your project, boardjinky4, instead of hijacking this one. :giggles
Offline boardjnky4
« Reply #78 on: March 05, 2019, 08:24:13 AM »
I thought my comments were relevant to the discussion?
  • North America
  • K1100LT
Offline Cromoly
« Reply #79 on: March 05, 2019, 04:03:24 PM »
* D186112E-95CA-43F8-957F-7C6E8D6C489C.jpeg (66.13 kB . 768x576 - viewed 638 times)
* A5F3746E-A98A-43B8-858C-7E5B91CE6946.jpeg (58.28 kB . 768x576 - viewed 559 times)
* 724510F9-E71E-4B8D-8A4E-02F1A37A0988.jpeg (44.47 kB . 768x576 - viewed 611 times)
* 4B72AAA4-C4CF-4A72-BE4B-2779BB743180.jpeg (53.97 kB . 768x576 - viewed 530 times)
Pics of today's work
The tank is here, battery box as well,
I think it looks good just aluminum color.
Half of the motogadjet instrument is hooked up.
I have a magnet speed sensor to install, it came with the instrument gauge, I will use the rear ABS sensor bracket to hold it in place since the ABS SECTOMY it is useless
 So far so good. Close to schedule, if only the snow could melt so i can get the bike outside and test start.
  • Quebec
  • K1100 cafe
Offline Cromoly
« Reply #80 on: March 08, 2019, 07:57:31 AM »
* 433430DC-1F71-49CA-A97C-46F7555F4A4A.jpeg (42.67 kB . 768x576 - viewed 570 times)
I striated plugging in to the BEP 3.0, pretty straightforward so far.
  • Quebec
  • K1100 cafe
