Author Topic: K75 / K100 Front Master Cylinder seals  (Read 5314 times)
Offline Quiltzig
  • K Guy
« on: November 15, 2018, 05:11:29 PM »
Can you buy the seals for the MC as a kit or do you need to get the whole piston with seals kit? Seems that latter is rather expensive.
  • Hamilton - New Zealand
  • K75S
1987 K75S - cafe racer project
2016 R9T (wifes ride)
2004 K1200RS
Offline Quiltzig
  • K Guy
Re: K75 / K100 Front Master Cylinder seals
« Reply #1 on: November 15, 2018, 07:32:30 PM »
It’s the 13mm MC with the square plastic reservoir and 3 screws securing the cover - am on mobile at moment so can’t find part number easilymoment so
  • K75S
2004 K1200RS
Offline alabrew
« Reply #2 on: November 16, 2018, 02:06:57 PM »
Best I know is that you can only buy the piston with the seals installed.
  • Birmingham, Alabama
  • 1985 K100, 1991 K100RS
Also:
2005 K1200LT
1979 R65
Offline KIWIDON
« Reply #3 on: November 16, 2018, 10:22:48 PM »
Last one I purchased was from BMW in Auckland as needed for daily rider and was close to NZ $180 for overhaul kit.
Can have for 39 Pounds ex UK so including freight (you will no doubt order other consumables) it will work out far cheaper. Purchased my rear cylinder kits for both K's from the UK.
  • AUCKLAND NEW ZEALAND
  • K75C, K75S, 61/65/68 T120, CAGIVA ELEFANT
« Reply #4 on: November 17, 2018, 12:02:39 AM »
There is a slight possibility if you know the dimensions of the cups that you might be able to source them from here. He is a nice guy and extremely helpful, I've sourced master cylinder boots from him. He also sleeves Brick front master cylinders, and once done a set of cups is around $10.00 AU. He doesn't like doing rear cylinders as the plastic part the reservoir connects to has a habit of breaking on removal. The end result he has to make a new one out of brass inflating the cost.
* Boots and cups supply[1].jpg (55.42 kB . 768x576 - viewed 546 times)
« Reply #5 on: November 17, 2018, 01:25:18 PM »
tills.de also has a full kit...
https://www.tills.de/brembo-piston-13mm-repl-bmw-32722302356.html
I found their replacement fan assembly first-rate, shipping reasonable and fast.
Offline Quiltzig
  • K Guy
« Reply #6 on: November 17, 2018, 01:47:41 PM »
Thanks to both of you for your helpful replies.
This forum is great!
  • K75S
2004 K1200RS
« Reply #7 on: November 17, 2018, 02:35:26 PM »
If he can supply cups, they can be hard to fit over the piston. He recommended using a couple of well linished screwdrivers with no sharp edges and lube well. Any sharp edges can cause nicks that could cause leaks or tears.
Offline natalena
« Reply #8 on: November 17, 2018, 02:53:15 PM »
Got a 13mm piston/spring/bushings assembly from Motobins in the UK for 50 pounds. Shipped amazingly fast to the "colonies" and was a direct fit that eliminated the nasty dribble.  It's the first thing that pops up on their website under Brakes/Front. Good luck
  • MST
Offline szabgab
« Reply #9 on: November 18, 2018, 06:22:39 AM »
Apart from ordering a new set,  did you try to clean them?   Many times all it takes is a godd scrub down,  it certainly helped my leaking front MC.  If that does not help,  at least you'll see what's at fault and what needs to be replaced
  • Budapest, Hungary
  • K75S 1985 model
Offline schrocketeer
« Reply #10 on: November 29, 2018, 10:57:34 AM »
A full piston with seals option is $63 US (plus shipping) from Beemer Boneyard https://www.beemerboneyard.com/32722302356.html
My install of this a couple of months ago on my '85 K100RT was pretty straight forward.
  • North Alabama
  • 1985 K100RT very original
Ken
