Author Topic: converting clock from 24 to 12 hour mode  (Read 5283 times)
« on: November 15, 2018, 05:41:41 AM »
i found an easy way to do this on the net
i disconnected and reconnected the battery and its reverted to 24 hour mode
i cant remember or find back the way to do it
Offline TX brick
Ron
91 K75RT
Belton Tx
Offline BlitzenGruv
Re: converting clock from 24 to 12 hour mode
« Reply #2 on: December 25, 2018, 02:13:50 AM »
And to think that I was happy that the BMW clock is the only one I don't have to change to get 24-hour time.
  • Crossville, TN
« Reply #3 on: December 25, 2018, 11:17:52 AM »
All my bricks have 12 hour clocks.  It's part of the instrument cluster work I do the first winter after I get a new bike.  Includes an LED retrofit, speedo calibration, and a deoxit spray of all the connector pins  I also do a mask of the Low Fuel and High Beam indicators to smaller dots so they don't blind me at night.
Offline natalena
« Reply #4 on: December 25, 2018, 04:32:18 PM »
Cool; although, the only place I've lived that it would matter is Alaska, where 1100 and 2300 are pretty much identical in summer. :)
  • MST
Offline Soggz
« Reply #5 on: January 07, 2019, 03:07:27 PM »
When I bought mine,I had a cheap digital watch strapped to the handlebars,as the clock dosnt work. Don't know why...any ideas?
  • Down in Selwood Forest
« Reply #6 on: January 07, 2019, 05:09:27 PM »
. . . the clock dosnt work. Don't know why...any ideas?
Doesn't keep time, or the numbers disappeared?
  • 1995 K75 89,000 miles
Offline Soggz
« Reply #7 on: January 07, 2019, 05:26:22 PM »
Hello again.
The clock never worked when I got the bike. No numbers.
« Reply #8 on: January 07, 2019, 07:32:53 PM »
The clock module LCD display is pretty fragile, in fact, the gear position indicator isn't too rugged either.  If you take the cluster apart, you need to show those two parts respect.
« Reply #9 on: January 07, 2019, 09:04:00 PM »
Hello again.
As TMG points out, the LCD modules on these bikes are old and fragile.  There is a conductive foam used to connect the LCD module to the clock module. This foam deteriorates and can loose contact with the LCD, resulting in no display.  It's pretty much impossible to replace this component and this renders the clock module useless.  Another symptom from these old displays is the liquid within the LCD bursts and causes the display to fail.  The symptom is a display that is completely obscured.  The display is custom for BMW and there is no equivalent replacement available on the market.
Offline Soggz
« Reply #10 on: January 08, 2019, 02:43:17 AM »
Ok. I’ll just have to go with the old digital watch. To be honest,I have a clock on my phone.
