Author Topic: Got Lucky today,... Fuel leaks !! K1100RS  (Read 7328 times)
Offline KCinSB
« on: October 28, 2018, 11:15:17 AM »
Just read the Tech post on replacing the hard/cracked rubber fuel lines on a K1100RS. Exactly my situation and a good tip if you haven't even considered the issue yet....... Like ME !   :johnny.
  How it came up: Long time bike sitting (over a year+ after busting the fairing in a garage drop!)
Fairings are all off, but decided to try and start the bike, just because.... Topped the AGM battery overnight. Pushed it outside, (turns out a VERY good idea always), cranks but no start. Not surprising I guess, but I'm mulling that over later on. DUHhh,  side stand is still down dummy,...... Remember it's been a year+, and my others don't save my butt like the BMW. Anyhow, next attempt, bike outside again, key on,.... Oh yeah, I remember now, I should hear that whine sound,.... Push start, cranks, starts, and I shut it off. There's a weird "Fog" in the sun light at the left side. Fuel mist is spraying into the air!!  So glad all the fairing is off, and that allowed the spray to be visable, and not simply contained inside the engine faired in area. A mist of gas like that is the most dangerous thing I can think of! Looked at the lines, and Yep! Cracked and brittle.
  Found the tech post after looking up the line in the parts Fiche, and realized there are more lines than the obvious ones. So, more take it apart is now the plan. Got lucky today.
  • Santa Barbara, CA
  • SOLD
Re: Got Lucky today,... Fuel leaks !! K1100RS
« Reply #1 on: October 28, 2018, 11:20:17 AM »
and that is why ALL the rubber lines (fuel, brake, vacuum and coolant) need to be replaced if more than 10-15 years old.   "low miles", "garage kept" or "they look fine" is irrelevant.  age kills them.
« Reply #2 on: October 28, 2018, 11:34:47 AM »
True especially for the fuel lines and most of the vacuum lines.  My 32 yr old K still has the original coolant lines though, they seem to be made from some ageless indestructorubber.
Offline JPaganel
« Reply #3 on: October 28, 2018, 11:38:44 AM »
and that is why ALL the rubber lines (fuel, brake and coolant) need to be replaced if more than 10-15 years old.   "low miles", "garage kept" or "they look fine" is irrelevant.  age kills them.
This.
I just replaced the original 1986 fuel line from tank to pressure regulator.  The outer layer delaminated, and it was literally seeping through the inner ones.  It was like a sweaty snake.
The nice thing is that technology progresses, and modern hoses are often light years better than the OE.  When I replace brake hoses on bikes I have them made at a local industrial hydraulics place. I get the top of the line teflon-cored, stainless braided, vinyl covered hose. It's pretty much eternal, as the rubber layer never touches brake fluid or sees UV.  The old rubber lines rot from the inside and rubber crumbs clog your brakes.
  • Minnesnowta
  • 1986 K100RT, 1996 R1100RS
Offline KCinSB
« Reply #4 on: November 09, 2018, 10:49:16 AM »
Has anyone here purchased replacement factory fuel lines for a K1100?  Were they OK recent manufacture or NOS, but very old and questionable. I am trying to come up with a good way to route the replacement fuel lines, and a couple of the sharp 90 deg bends are a bit "iffy".....  If new ones are available and not junk I think I'd pay the price.
  Also, best place to buy them?
  • Santa Barbara, CA
  • SOLD
« Reply #5 on: November 09, 2018, 01:15:42 PM »
i have got new ones from BMW dealer and they are good.
Offline KCinSB
« Reply #6 on: November 09, 2018, 01:28:04 PM »
Thanks for the reply!  Good news. I'll give them a try also.  Regards, KC
  • Santa Barbara, CA
  • SOLD
« Reply #7 on: November 09, 2018, 01:34:24 PM »
CalMoto seems like a good source for you. I use MAX BMW in New Hampshire.
Offline KCinSB
« Reply #8 on: November 09, 2018, 03:02:37 PM »
Just finished with an on line order with the BMW Ventura County folks. The site is very good, no glitches. I hope the order comes in as well!  3 hoses, some rear tank grommets, 4 small throttle body caps and clamps. Each part was checked for fitment, and confirmed: "this part will fit your '93 K1100RS".  So far so good.... !
  • Santa Barbara, CA
  • SOLD
Offline KCinSB
« Reply #9 on: November 17, 2018, 11:09:58 AM »
UPDATE: Just for those interested.  The 3 lines I'm replacing are the fuel lines. Tank outlet (pump) to fuel rail, fuel rail to press regulator, press reg return to tank. All 3 show the multiple cracks linear along the length of the 1993 tubing. BMW did have replacement parts, and they are dated recent mfr, so confident they will last awhile. (longer than I'll be riding........)  It's a process to get there, but an opportunity to clean up the motor. I just hope after this fix, the long time sitting doesn't present a bunch of other repairs needed. No way to find out but to give it a try..........  Starting reassembly today. Took pictures to help my old memory!!
  • Santa Barbara, CA
  • SOLD
« Reply #10 on: November 17, 2018, 11:51:07 AM »
Trust me, all this work you're doing, it's gonna pay off in the end.
An old brick is kinda like a new girlfriend.  You gotta put what seems like a lot of time and energy(some money, too) in at the beginning, but the end result is almost always worth it.
And sometimes the end results are better with the brick than the girlfriend, just sayin'.
Offline KCinSB
« Reply #11 on: November 17, 2018, 01:00:47 PM »
Just noticed something,. The photos here show on my desk top PC, but do not show in the post if I look at it on the iPad................  ??
  • Santa Barbara, CA
  • SOLD
« Reply #12 on: November 17, 2018, 01:45:43 PM »
That's good news! If you hadn't noticed they were missing, they probably weren't much to look at in the first place. Keep up the good work!
Offline Nine80seven
« Reply #13 on: November 18, 2018, 09:30:34 PM »
Good work.  Clean as you go.  Did the same to my '85 KRS.  Replaced rubber as I went through it, with the best as needed.  No one cares for yer ass like yerself.
  • MN
  • 85 K100RS
