Author Topic: Valves  (Read 8313 times)
Offline JPaganel
Valves
« on: October 24, 2018, 01:26:36 AM »
Checked valves today.  Yikes.
Intakes are sorta tight, exhausts are pretty damn tight.  Good thing I didn't actually start flogging this thing.
Now, I need to figure out a way to make the tool.  If that doesn't come together, I can always try the copper wire trick I used on my Yamahas.
Speaking of Yamahas.  The shims seem to be the same 29mm that they use.  Is that right?
  • Minnesnowta
  • 1986 K100RT, 1996 R1100RS
Re: Valves
« Reply #1 on: October 24, 2018, 03:29:48 AM »
Maybe. Maybe not.
Re: Valves
« Reply #2 on: October 24, 2018, 07:39:31 AM »
Ken Lively makes a good tool set for a great price and I bought shims from here -> https://www.newmotorcycleparts.net/motor_parts/valve_shims.html
Offline JPaganel
Re: Valves
« Reply #3 on: October 24, 2018, 09:49:44 AM »
Maybe. Maybe not.
Hm. I don't remember seeing any chamfer on the shims last time I did valves on my XJ...
Granted, that was a while ago, and I might be misremembering.
  • Minnesnowta
Re: Valves
« Reply #4 on: October 24, 2018, 03:35:31 PM »
this..
just buy the tool from Ken.  cheap and ez.
Offline John Lang
  • John Lang
Re: Valves
« Reply #5 on: October 24, 2018, 06:11:01 PM »
I used a Kawasaki 29mm spacer. My BMW/Kawasaki/Triumph dealer had the thickness I needed in stock, and it was a bit cheaper.
  • Ottawa, ON Canada
Offline gone_ape
  • 94 K75RT (Now Standard)
Re: Valves
« Reply #6 on: October 24, 2018, 09:14:24 PM »
I concur on Ken Lively's tools.  I have them and they work great - fuss free and it's soooo much more enjoyable to have the right tool instead of rummaging through your tool box for alternatives that will screw it up for you.
Buy them...He ships fast and you will not regret it.....
  • Austin, TX
Re: Valves
« Reply #7 on: October 24, 2018, 09:48:49 PM »
My k100 uses the same shims as my '83 Yamaha xs400.
Get the right tools for the job.
Offline brichbk
Re: Valves
« Reply #8 on: October 25, 2018, 01:22:50 PM »
i just ordered the valve tool from Polepenhollow Valve Tools and Clutch Pilots, polepenhollow@yahoo.com.  I ordered in the evening and he shipped the next day.  I've got 5-6 shims to remove so having the right tool will be very helpful.
  • Central Valley California
  • 1993 BMW K75RT // 1982 Honda Nighthawk 650sc
Re: Valves
« Reply #9 on: October 25, 2018, 09:45:42 PM »
Good move.
Supporting Ken helps us all.
Offline JPaganel
Re: Valves
« Reply #10 on: October 25, 2018, 11:33:00 PM »
Being cheap an impatient I made my own tool.
All the shims had the numbers worn off. This was unpleasant - Yamaha shims keep their numbers better.
I got a caliper and measured.  Does this math look good?
Intake
Clearance 0.14 0.14 0.14 0.11
Shim 2.50 2.55 2.60 2.60
New shim 2.45   2.50 2.55 2.50
Exhaust
Clearance 0.07 0.11 0.24 0.16
Shim 2.50 2.50 2.40 2.50
New shim 2.30 2.30 2.35 2.35
As far as I can tell, a couple will make it over maximum, but just barely. Loose is better than tight, and going the other way would give me just over the minimum.
  • Minnesnowta
Re: Valves
« Reply #11 on: October 26, 2018, 02:10:59 AM »
All the shims had the numbers worn off. This was unpleasant  Does this math look good?
Intake  Loose is better than tight, and going the other way would give me just over the minimum.
This is a nothing-burger—just subtraction and addition. If you're already convinced of the outcomes, what's left for discussion? The unpleasant part is behind you, apparently.  Forward, the Light Brigade! Charge for the guns!
Offline JPaganel
Re: Valves
« Reply #12 on: October 27, 2018, 07:37:17 PM »
This turned out kind of amazing.
I called up the local BMW bike dealer to get a baseline on the shim price.
I got this guy, he says "you sure it's the old K100?", I say it's an 86. He says it's the first BMW he worked on, the bike he started on as a mechanic.  And then he says he has a shim kit, his personal one, not belonging to the shop. And I can just borrow it. Free.
I show up, expecting to pay a deposit, or leave something as collateral. Nothing. He just hands me the two boxes and says to bring them back tomorrow.
So, I got my valves set for free with OEM shims. And the bike runs nice.
  • Minnesnowta
Re: Valves
« Reply #13 on: October 27, 2018, 09:17:29 PM »
Wow that is a result! Congratulations. :clap:
Re: Valves
« Reply #14 on: October 28, 2018, 03:50:03 PM »
I'd take him a bottle of something, or at least a six pack as a sign of appreciation and his trust. It is good to see things like this are still happening.
Re: Valves
« Reply #15 on: October 28, 2018, 06:40:03 PM »
At least...
Offline lmiklosy
  • One Less Car
  • Freude am Fahren!
Re: Valves
« Reply #16 on: November 28, 2018, 01:48:30 PM »
What is the most common thickness of shim found on stock engines, that is what shim is used most often when these motors were manufactured?  (Maybe  2.50mm)   Maybe frankenduck Laitch Martin Chaos knows?  Thank you.
  • Laguna Beach, CA
  • 1993 K75S-Mystic, 1981 R100RS-RedBaron, 1991 K75S-Marrakech
