Symptoms:
- dash lights up when key turned on but headlight does not (small running light does come on at first key position).
- pushing start button activates starter relay (click)and causes buzz (from fuel pump?) but does not crank engine at all.
- a few times, after waiting a few minutes, symptoms disappeared and engine cranked and started; the headlight came on but flickered at idle.
- once, I noticed all four flashers came on as I signalled a turn.
My diagnosis:
Headlight flicker at idle indicates bad battery. It is 5 years old.
But multimeter reads 12.8V and, when it does crank, there is no hesitation.
Ignition switch needs cleaning.
Possible but wiggling the key does not reveal a short or gummed switch.
Load shed relay is shot.
But, swapped it with the horn relay and problem remained.
Dirty ground connection.
Cleaned battery terminals, ground connection to transmission housing, main ground connection under tank.
Result: no change.
Battery, ignition switch and starter motor (gah!) remain as possible culprits.
Other ideas?
