Author Topic: Throttle cable routing  (Read 2642 times)
Offline JPaganel
« on: September 28, 2018, 09:09:17 PM »
I think there is an issue with my throttle cable. Idle increases when I turn the bars right, so it seems like it's getting pulled.
What is the correct way for it to be routed with the C style small fairing?
  • Minnesnowta
  • 1986 K100RT, 1996 R1100RS
Offline JPaganel
Re: Throttle cable routing
« Reply #1 on: September 30, 2018, 08:52:43 PM »
For future reference, I figured it out.
The cables are supposed to go between the rubber pad where ignition lock sits and the dash, and then between a fork leg and the head tube and into the frame.
If cables are routed outside the fork, when you turn it presses on them and pulls them.
  • Minnesnowta
