Author Topic: No spark 1 and 4 ***SOLVED***  (Read 3245 times)
Offline ileumi
« on: September 19, 2018, 08:16:35 AM »
Hello. Still fighting with cafe racer...
Ok. Finaly I find problem with loss power. Cylinders 1 and 4 are cold.
No spark on them.... What I Know? Ignition coils are fine. When I change control wires to coils, spark losses in 2/3 and 1/4 lives.
Ignition output stage  fine. My friend borrow me another, and problem wont fix.
I read fault digits in motronic, only hall sensor 2 is active but I think that is "ghost".
I test sensors with led-indicator and both of are fine.
So far, so close? Anything hints?
Kiitos etukäteen :)
-Ike-
  • Everywhere
  • Xchallenge/GSF1200/K100RS-91
Offline ileumi
Re: No spark 1 and 4
« Reply #1 on: September 19, 2018, 08:56:52 AM »
And +12VDC inputs both of coils, when power is on.
  • Everywhere
« Reply #2 on: September 19, 2018, 10:22:49 AM »
When you blocked each sensor's gap the light shut off?
Offline ileumi
Re: No spark 1 and 4 ***SOLVED***
« Reply #3 on: September 19, 2018, 11:54:47 AM »
Yes Laicth, it will shut off. In test I use normal Duspol universal electric tester.
Problem was worn pin in Motronic. That pin feeds ICU.
-Ike-
  • Everywhere
