Author Topic: gravel riding on k75  (Read 4325 times)
Offline burntstick
« on: September 17, 2018, 09:41:36 PM »
Any tips for gravel road riding on a k75 appreciated .Such as tire selection , engine protection or any other pros and cons .Thanks
  • under tarp
  • 91 75rt or maybe 92
Offline Skunky
Re: gravel riding on k75
« Reply #1 on: September 17, 2018, 11:46:00 PM »
Hold on Tight it's gonna be bumpy  :2thumbup:. Remember its not a dirt bike its heavy and being shaft drive puts a lot of power on the back wheel without the slight flex a chain gives.  Any old knobbly tyre will do. Or get a GS and save the 75 for the tarmac it was designed for.
  • Derby GB
  • BMW K100lt BMWK1100lt
90 K100lt 97 K1100lt
Honda FMX650 Honda CB400F
« Reply #2 on: September 18, 2018, 08:04:24 AM »
Cut the lever off the front brake so you can't use it and paint the bike with driveway sealer.
Disabling the front brake will reduce the frequency of crashes and the driveway sealer is easy to touch up.
« Reply #3 on: September 18, 2018, 10:48:02 AM »
Cut the lever off the front brake so you can't use it...
 :clap: Great idea, you could also hack it, then you can ride in the snow too.
Offline beemuker
« Reply #4 on: September 18, 2018, 10:53:34 AM »
go slow, but not too slow. don't use front brake, unless you want excitement.
  • Panama City, FL
« Reply #5 on: October 23, 2018, 08:26:37 PM »
I've done it a few times. Several miles worth of jeep trails on my last trip.
Sand is hard. Knobby tires will help. I don't have them. Just go slow.
What I tend to do that helps is to either put the engine in fast idle mode or disconnect the TPS connector. That way you don't have the idle cutoff and get a sudden change in torque on the wheel if you let off the throttle without pulling the clutch.
