Author Topic: Can not budge Tranny fill plug  (Read 4211 times)
Offline TaosBob101
« on: September 15, 2018, 11:47:33 AM »
 It wont budge, 13k on bike, 95 K75S, no past service records. Did final drive last night. Dark, it needed it.Tried to unloosen tranny fill plug. 8mm allen 3/8 drive socket. May have to buy 3/8 breaker bar. Stopped, so plug not buggered.
So , sitting here frustrated.Should not be this tight!
Ideas?
  • Jefferson County, Colorado
  • 1995 K75S
1995 K75S
Offline mw074
Re: Can not budge Tranny fill plug
« Reply #1 on: September 15, 2018, 11:58:01 AM »
Try a little bit of heat around it with a propane torch. You have to be able to change the oil.
  • Michigan
Offline TaosBob101
« Reply #2 on: September 15, 2018, 12:05:35 PM »
Thanks , will do.Post back.
  • 1995 K75S
1995 K75S
« Reply #3 on: September 15, 2018, 01:14:28 PM »
+1 on heat, also a hammer impact wrench with an allen head socket may work.  If it does get buggered don't fret, I've ground down the tips of old easy outs to fit tight in the hole with some hammering.  One mechanic recommended star sockets.  Either way try soaking it overnight in PB Blaster or equivalent too.
« Reply #4 on: September 15, 2018, 01:15:45 PM »
+1 on the heat.  I have the same problem with my K75RT.  The torque to loosen the transmission fill plug is about 3 or 4 times what it's tightened to.  I put anti-seize on it and it does nothing.
Offline TaosBob101
« Reply #5 on: September 15, 2018, 02:36:05 PM »
 Got....it!!!!! Thanks Brothers!!!
  • 1995 K75S
1995 K75S
Offline blackie1
  • christchurch nz
« Reply #6 on: September 15, 2018, 11:18:28 PM »
got it..... as in thanks for the info
got it..... as in you managed to loosen it
if you did manage to loosen it , how did you do it?
  • 1991 K75RT naked 67,000kms
Offline TaosBob101
« Reply #7 on: September 16, 2018, 06:24:30 PM »
A tiny bit of heat.....8mm allen w pipe as a cheater bar. It "snapped" loose. Anti seize on the threads. I think it was original gear oil at 13k. Maybe not....no service records
  • 1995 K75S
1995 K75S
