Author Topic: K100RS 1984 no spark  (Read 3343 times)
Offline mister_anger
« on: September 02, 2018, 11:14:44 AM »
hello,
I have been working on my K100RS for 8 months and the project is done.
I am trying to start the bike but it will not start.
I have spark on spark plug 1 and 4 but nothing on 2 and 3.
Ignition coils are brand new and are OK.
I have a document that tells me how to trounleshoot everything but I am not elecrtician so I have a question.
I think the EFI is the problem.
The document tells me that I should measure 1.5 to 4 Volt AC on pin 9-10-14 of the female plug of the EFI.
I have no idea on how the measure this? Maybe someone can run me through this?
thanks, Miochel
  • Belgium
  • Triumph speed triple, honda cbx750f, BMW K100RS
Offline bluebossa
  • K75 and R65 Owner
Re: K100RS 1984 no spark
« Reply #1 on: September 23, 2018, 12:39:16 PM »
I've troubleshot a few of these now.
Forget efi for a while, just take tank off, clean every connector, and I mean everything.
Take earth's off on frame, clean with grit paper, reassemble... Report back
  • UK
  • K75C
Current Bikes: K75 (C) in the UK (1986), R45 (1981)
Former Bikes:  K75RT, K75S, R850R, K1100RS, Dnepr MT10-36, R1200GS, K100, R100T, R100RT.
BMW R45 and K75 Blog
« Reply #2 on: September 23, 2018, 06:42:43 PM »
what he said.  the #1 item for no start is bad electrical connections...especially the grounds.  main ground under tank and main ground at battery.  BTDT.
« Reply #3 on: September 23, 2018, 07:07:35 PM »
This is one of those occasions when a problem was posted in a couple of places but the OP didn't follow up on one of them. The problem was posed then the solution apparently found by the OP in this thread—a faulty Hall Effect Sensor.
